Amplifier Connector Bar - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-26-2013, 02:19 PM - Thread Starter
clovenhooves's Avatar
This is kind of obscure, but I'm trying to find some metal connector bars that go in the back of an old AVR. In the Pre Amp Out jacks. That seems to be the correct name, according to the manual. Are they one-size-fits-all, and how to acquire them?
clovenhooves is offline
post #2 of 5 Old 01-26-2013, 02:43 PM
Theresa's Avatar
Liked: 51
Wont a RCA cable work instead of the "bar?"
Theresa is offline
post #3 of 5 Old 01-26-2013, 08:46 PM - Thread Starter
I started wondering that a few hours ago. Does anyone know for sure?
post #4 of 5 Old 01-26-2013, 09:06 PM
jdcrox's Avatar
Quoted: 78 Post(s)
Liked: 102
If you are talking about the bars that go between the "pre-out" and "main-in", then yes you can just use some RCA cables with no issues. Just a little messier. tongue.gif
jdcrox is offline
post #5 of 5 Old 02-07-2013, 11:46 AM - Thread Starter
I've decided I should get at least one more connector bar, if possible. I just need sources. I know that old Pioneer AVRs came with them. Names of other brands that had them, please?
