Yamaha RX-A820 receiver - Will it run it? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-26-2013, 06:50 PM - Thread Starter
garetjax's Avatar
Looking to pick up a Yamaha RX-A820 receiver to use with one of the following set of floorspeakers (I haven't decided which ones yet):
Klipsch FK-28
Energy CF-70
Polk RTi A9
Is the Yamaha RX-A820 adequate enough to run any of these floorspeakers, especially the RTi A9's, and will the RX-A820 be able to successfully bi-amp any of speakers without problems?
garetjax is offline
post #2 of 6 Old 01-27-2013, 05:52 PM - Thread Starter
garetjax's Avatar
Anyone? =(
garetjax is offline
post #3 of 6 Old 01-27-2013, 06:08 PM
GaryWA's Avatar
Quoted: 16 Post(s)
Yes it will be fine. Will the Polks like more power? Probably.
http://www.avsforum.com/t/1402293/bi-amping-question
There is also no/little benefit to bi-amping, or rather, passive bi-amping.
GaryWA is offline
post #4 of 6 Old 01-27-2013, 07:25 PM - Thread Starter
garetjax's Avatar
How much power do you think the Polks need?
garetjax is offline
post #5 of 6 Old 01-27-2013, 07:36 PM
afrogt's Avatar
Quoted: 1432 Post(s)
Liked: 982
Depends on the size of your room and how loud you play your system.
Good thing about the A820 is you can always add an external amp if necessary.
Afro GT
afrogt is offline
post #6 of 6 Old 01-27-2013, 09:21 PM
GaryWA's Avatar
Quoted: 16 Post(s)
This is how much they would probably like.
http://shop.emotiva.com/collections/amplifiers/products/xpa2
But if you're not listening to them super loud, you won't need it.
GaryWA is offline
Yamaha Rx A820 7 2 Channel Network Aventage Av Receiver , Energy Cf 70 Floor Standing Speaker Black , Polk Audio Rti A9 High Performance Floorstanding Loudspeaker Each Black
