remote app - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-27-2013, 07:31 AM - Thread Starter
rogueag's Avatar
I had the denon remote app for my ipad and it works okay. I accidentally removed it this morning. When I went to the app store to re install, it no longer shows up. Any thoughts on where to find it and re install would be appreciated.
rogueag is offline
post #2 of 5 Old 01-27-2013, 07:37 AM
highdefav1's Avatar
Quoted: 106 Post(s)
Liked: 37
Since you had it initially, did you sync you're iPad to your iTunes? Or back it up to the cloud?
If not, you may want to call Denon and see if they removed the app for some reason.
Panasonic 55ST50
Yamaha RX-V673
Klipsch RF-52 II // RC-52 II // RS-42 II
Klipsch RW-12d
Klipsch KG 2.5
highdefav1 is offline
post #3 of 5 Old 01-27-2013, 07:57 AM - Thread Starter
rogueag's Avatar
thanks, I will have to call Denon on Monday to find out what happened to the app.
rogueag is offline
post #4 of 5 Old 01-28-2013, 06:15 PM - Thread Starter
rogueag's Avatar
I was able to reinstall the Denon app from the backup for my iphone. Thanks Highdefav1. I called Denon about why the app was no longer on the apple site. No good reponse other than we will look into this.
rogueag is offline
post #5 of 5 Old 01-28-2013, 08:12 PM
highdefav1's Avatar
Quoted: 106 Post(s)
Liked: 37
No problem...glad to hear you were able to get it back on the iPad. Peculiar why it was taken down from the app store.
Panasonic 55ST50
Yamaha RX-V673
Klipsch RW-12d
Klipsch KG 2.5
