PCM QUESTION ON RECEIVER SC-61 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-27-2013, 10:35 AM - Thread Starter
SF FAN's Avatar
Just got this receiver a few weeks ago along with a blue ray DVD player and was watching batman last night and it shows PCM on the receiver. Is that normal and Is there a way to change it to Dolby pro logic and if so is that a better option?
Tanks!
SF FAN is offline
post #2 of 7 Old 01-27-2013, 11:19 AM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 756
You don't want Dolby Pro Logic if you're watch blu ray. You want TrueHD or DTS-MA.
Sounds like your blu ray player isn't setup properly. What model is it? The receiver just decodes whatever signal it is being sent.
And which Batman movie are you referring to? There are several. I know the Dark Knight (the one with the Joker) doesn't automatically default to TrueHD, you have to select it from the audio menu.
Are you watching the blu ray movie or a DVD movie?
Afro GT
afrogt is online now
post #3 of 7 Old 01-27-2013, 11:40 AM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
^^^ +1
Hi SF FAN, hopefully you have connected the bluray player to receiver with HDMI cable and not RCA (yellow,white,red) cables. As afrogt posted, the bluray audio output is not set up properly for HD audio for BD viewing. Go into bluray player audio menu and set the HDMI Audio Out as "Bitstream" and Secondary Audio as "Off".
JChin is offline
post #4 of 7 Old 01-27-2013, 11:47 AM - Thread Starter
SF FAN's Avatar
Yeah I ran the blueray with a Hdmi cable . I was watching batman returns and tonight I'm watching the dark night. So what do I need to do ??
Thanks again !!!!!
SF FAN is offline
post #5 of 7 Old 01-27-2013, 11:53 AM
afrogt's Avatar
Liked: 756
What model blu ray player do you have?
Like JChin said you most likely need to set the player to BITSTREAM and the secondary audio to OFF
Afro GT
post #6 of 7 Old 01-27-2013, 12:12 PM - Thread Starter
SF FAN's Avatar
Pioneer elite bdp-62 fd
SF FAN is offline
post #7 of 7 Old 01-28-2013, 02:06 PM - Thread Starter
SF FAN's Avatar
Anything ??
SF FAN is offline
