Upgrade from Onkyo NR-708 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-27-2013, 09:57 AM - Thread Starter
Howie411's Avatar
Quoted: 16 Post(s)
So I'm looking to upgrade my receiver, currently have the NR-708 and I've been looking at the NR-717 now that the price is falling. This one seems better in most aspects except it doesn't have the MultiEQ.
Anyone used both and can tell me which they liked more? Or if its even worth upgrading?
Howie411 is offline
post #2 of 4 Old 01-28-2013, 06:12 AM - Thread Starter
Howie411's Avatar
Quoted: 16 Post(s)
Anyone? Is it worth upgrading?
Howie411 is offline
post #3 of 4 Old 05-07-2013, 10:38 AM
Old AV Buff's Avatar
Are you having problems with it? I just bought one used, an upgrade from a TX-SR706 I had and loved, but would not pass 3D signal. It does a lot considering it is now about 3 years old. If it is working fine, does it do what you need? What other unit are you looking at? Will it give you more bang for your buck?
Old AV Buff is offline
post #4 of 4 Old 05-10-2013, 02:02 AM
AVTrauma's Avatar
Is your 708 "underperforming"? Upgrade to make things better, yup... but the 717 won't add much with the lack of MultiEQ.
AVTrauma is offline
Onkyo Tx Nr708
