Denon AVR 2311ci display not working - AVS Forum | Home Theater Discussions And Reviews
Old 01-28-2013, 01:40 PM - Thread Starter
brianm26's Avatar
I have a Denon avr 2311ci that has no display. I turn it on and the sound still works but no display on the unit. I checked the dimmer to make sure it was off. Also reset the unit, still no luck . Does anyone know what the problem could be ? Is there a fuse or something to replace? Thanks for the help
brianm26 is offline
Old 01-28-2013, 03:17 PM - Thread Starter
brianm26's Avatar
Can anyone help?
brianm26 is offline
Old 01-28-2013, 04:20 PM
budwich's Avatar
Quoted: 62 Post(s)
Liked: 31
How did you check that the dimmer was off?
budwich is offline
Old 01-28-2013, 07:02 PM - Thread Starter
brianm26's Avatar
There is a dimmer button on the receiver
brianm26 is offline
Old 01-31-2013, 12:08 PM - Thread Starter
brianm26's Avatar
This site ****ing sucks! No ****ing help!
brianm26 is offline
Old 01-31-2013, 12:27 PM
Yosh70's Avatar
Quoted: 172 Post(s)
Liked: 126
I had the same problem on my older Denon so I tried what this one guy from this forum advised......and it worked!
Mind you, you have to follow it step by step.
1) fdgrehthttyt4uytyhfh grgergret43b u7u87.
2) Sgrty54fr65654yhgjtyhjg gfgdfsghfe gfg
and last 3) gfhtrui9890 ui7 ui uyu 656uyhththgfh.
Damn keyboard....it literally sucks.
Oh well, lemme know how it goes. Good luck!
Yosh70 is offline
Old 01-31-2013, 07:17 PM
jdsmoothie's Avatar
Quoted: 12079 Post(s)
Liked: 5501
If you spent some time searching the various threads, you would learn there is a wealth of knowledge available to you even without receiving a direct response to your question. Try resetting the microprocessor as listed in your Owner's manual.
jdsmoothie is offline
Denon Avr 2311ci Receiver
