Budget Stereo Amp, integrated or power, for 4-ohm speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 01-28-2013, 05:02 PM - Thread Starter
niksfin's Avatar
Hey,
Here is yet another thread about stereo amps. I hate to ask but here it goes:
I'm looking for something to drive my new pair of front speakers. Their nominal impedance is 4-ohm. I don't need anything HDMI fancy stuff. Just something that will help me drive anything I use as front left/ right. I'm hoping for something with more than 100w per channel continuous through 8-ohm.
- no need for optical input
- really stable driving 4-ohm
- no crossovers needed
- new or used doesn't matter. must be enough for next 2-3 years
I was thinking about HK 3490 (new or used), NAD C326bee used (though less than 100w) etc.
What would you suggest? Other brands/models welcome. Budget - $250-$300.
Thanks in advance.
niksfin is offline
post #2 of 8 Old 01-28-2013, 09:17 PM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3078
I would be inclined to go with the HK 3490. You'll save some money and it has plenty of power.
Living Room: B&W 804D, B&W CMC S2, B&W ASW610, Yamaha RX-A2030, Rotel RC-1570, Rotel RB-1582 mkii, Oppo BDP-93, ATV.
postrokfan is offline
post #3 of 8 Old 01-29-2013, 11:39 AM - Thread Starter
niksfin's Avatar
From sound quality point of view, is NAD better or HK?
Also, no other suggestions like Emotiva UPA-200 or Rotel Power amps?
niksfin is offline
post #4 of 8 Old 01-29-2013, 10:35 PM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3078
NAD SQ is excellent. However, with the HK you will get excellent SQ for less money. You will need a pre-amp with a power amp of course. Do you have one available or have you increased your budget? Also, the UPA-200 and Rotel are well outside your budget of $250-300 unless you get lucky with a used deal.
post #5 of 8 Old 01-29-2013, 11:03 PM - Thread Starter
niksfin's Avatar
No, I have not increased my budget.
On the other thing... I'm little confused about the components in audio system. As in what comes after what, which component can be skipped etc. E.g. I was thinking about using Dragonfly dac with those power amps using mini-jack to dual RCA cable. But I guess I need to put a pre-amp in there somewhere. I don't know for sure.
Time to find some good material to read!
niksfin is offline
post #6 of 8 Old 01-30-2013, 09:34 AM - Thread Starter
niksfin's Avatar
Apologies for the double post but used Emotiva UPA-2 is available for $250 + shipping. So, it's within budget.
Any opinions anyone?
niksfin is offline
post #7 of 8 Old 01-30-2013, 04:22 PM
crussader's Avatar
Quoted: 49 Post(s)
Liked: 29
Emotiva is well regarded around here.
I am loving my upa-500 that I bought last month.
Emotiva amps come with a 5 year transferable warranty. They stand behind their products.
David
crussader is offline
post #8 of 8 Old 01-30-2013, 08:50 PM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3078
You will need a source with a volume control or an analog/digital pre-amp to go with the UPA-200. A used Emotiva USP-1 (analog pre-amp with tons of connectivity and even bass management) or XDA-1 (digital preamp/DAC). You don't necessarily have to go with the same brand pre-amp. Another option would be the Parasound Zpre2 (very simple pre-amp with 4 audio inputs and tone controls, $299 for a refurbished unit). Or you could go with something from TCC, www.phonopreamps.com for a lot cheaper.
