Loud/Soft dialogue issue with Harmon Kardon AVR2600 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-29-2013, 06:30 AM - Thread Starter
jev55's Avatar
I was wondering if anyone could help me out with an issue I am having. I'm having problems getting clarity in the dialogue of movies or tv programs I am watching when using my surround setup. Even with the volume at a high level (85db base) the dialoge is audible but not easily understandable. My setup is as follows.
Harmon Kardon AVR 2600
Polk Monitor 50 L/R speakers
Polk CS1 Center
Polk pw10 sub
Polk T15 surrounds
*Front, surround, and sub speakers are all leveled to the same db level. Center channel is about 2db louder than other speakers.
I have tried the "Dolby Volume" setting on my receiver and have found it only muddies the sound and doesn't help bring dialoge out of the mix.
Does anyone know if replacing my receiver with say a Denon 1913 model would improve this issue? Or is my issue more of a "speaker" problem. Any help is appreciated. Thanks.
jev55 is offline
post #2 of 7 Old 01-29-2013, 09:22 AM
T2k
T2k's Avatar
Polk CS1 Center
Polk pw10 sub
Polk T15 surrounds
It does not sound like an AVR issue unless your room correction got borked... did you run EZSet/EQ?
T2k is offline
post #3 of 7 Old 01-29-2013, 09:58 AM - Thread Starter
jev55's Avatar
I did run the calibration but wasn't very happy with the results. The calibration had the bass set way too high and still had issues with dialogue. Also it misjudged speaker distance and crossover size. The Polk center speaker is matched up with my fronts so I didn't think I was a speaker issue. Granted they are not "high" end speakers. I was wondering if I should look to try a different center channel or try a different receiver next.
jev55 is offline
post #4 of 7 Old 01-29-2013, 11:12 AM
Espo77's Avatar
Quoted: 182 Post(s)
Liked: 85
Polk CS1 Center
Polk pw10 sub
Polk T15 surrounds
I would love to see a picture of the room and the positioning of the front sound stage. My gut feeling says that you have acoustic room problems, and or speaker placement issues. Are all three front speakers tweeters at seated ear level? Where is the center speaker...on a shelf, pushed toward the rear of the shelf? If so bring it way forward to the edge. If it is on a stand, pull it forward into the room more, and angle the tweeter towards your ears. Is the sofa on the rear wall? What kind of floors...carpet...tile...hardwood?
A new receiver is not going to help with any of the above issues.
Espo77's living room equipment: RECEIVER: Yamaha RX-A3030- SPEAKERS: Boston Acoustics M350, M25 center, surrounds, and front heights-
BLU-RAY: Oppo BDP103D- SUBWOOFER: HSU VTF-15H MK2- dedicated circuits for A/V- TV: Vizio P55C-1
Auralex Acoustics LENRD - Auralex Acoustics Roominator
Espo77 is offline
post #5 of 7 Old 01-29-2013, 11:17 AM
Knucklehead90's Avatar
Quoted: 498 Post(s)
Liked: 430
You can reset the volume levels for any channel - including bass in the setup menu. You can also manually run the speaker level control. I does sound like you have some reflection problems as Espo eluded to above.
Yamaha CX-A5000 - Acurus A100x3 & Outlaw 7075 amps - Salk Song Towers - Oppo 103
Vinyl Room: Emotiva PT-100 - ST-120 amp - Acoustic Research AR-2ax - Marantz TT42 - Oppo 103
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is offline
post #6 of 7 Old 01-30-2013, 05:08 AM - Thread Starter
jev55's Avatar
I will post some pictures later today. I have played around with resetting all of the volumes on the different channels. The most acceptable results I have gotten has been by turning the center channel to +2db and lowering the Front L and R's to -1db. The surrounds positioned next to my couch are set to -2db.(This matches the volumes of the fronts.)
These settings allow dialog to be heard more clearly but the center channel definitely "pops" out of the mix. Almost so that the surround effect is lost.
jev55 is offline
post #7 of 7 Old 01-30-2013, 06:37 PM
Espo77's Avatar
Quoted: 182 Post(s)
Liked: 85
Not sure what you mean by center channel "pops"out of the mix...but that might be exactly what the producer intended...dialog discretely coming from the center channel, and little or nothing coming from the surrounds.
I would like for you to describe the location of all of your speakers, and what decor you have in the room. You don't seem to want to answer those type of questions...???
Are you using a sound pressure level meter? With this tool you are balancing all speakers so that their volume at the seating area is equal. Just trying to help, but you're not providing enough information.
Espo77 is offline
