I am New and need some help. Onkyo tx-sr707 dropping left rear channel - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-29-2013, 11:34 AM - Thread Starter
bcharlsen's Avatar
I have a Onkyo TX-SR707 and i am having problem with the left rear channels dropping audio. I get static some times, but then sometimes i hear very little sound, and then sometimes i get nothing. Also when i lisen to music , i.e. aux ipod hook up 3.5mm to left and right audio inputs to front of the reciever i use 5 ch audio and i can get audio out of the left rear. I have done a master reset several times and it doesn't work. also i can't use my set up mic to calibrate any audio settings. If someone can help me out that would be awesome. i am trying to fix this myself and also if someone has a wireing diagram maybe i can use that. HELP!!!!!!!!!
bcharlsen is offline
post #2 of 3 Old 03-03-2013, 11:46 AM
motorman455's Avatar
I have an Onkyo 906 and have the exact same problem. The left surround channel is completely dead. I measured the resistance and it's 40 mega Ohms while the other channels are all around 30-40 Ohms. It appears the circuit in the receiver is pretty much open. I think we are screwed....
motorman455 is offline
post #3 of 3 Old 03-04-2013, 08:41 AM - Thread Starter
bcharlsen's Avatar
so did you end up getting it fixed or did yo just go ahead and buy a new one?
Onkyo Tx Sr707 7 2 Channel A V Surround Home Theater Receiver
