denon avr-791 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-29-2013, 12:20 PM - Thread Starter
gazoo0000's Avatar
hey guys... my receiver goes to multi-channel when i put in a blue ray disc in the ps3 and samsung blueray player as well. Before it would show dobly digital. my settings seem to be correct in the ps3 and samsung blueray player. Is there a way to get back 5.1 surround sound like i had before??
gazoo0000 is offline
post #2 of 5 Old 01-29-2013, 05:36 PM
jdsmoothie's Avatar
Quoted: 15333 Post(s)
Liked: 7488
Before what? Something changed to reset your settings back to PCM apparently. Check your settings on the PS3 and Samsung again as well as ensuring that "Secondary Audio" is disabled on the Samsung. You can also try resetting each device while connected to the 791 so it sees a multi channel receiver. Note though that regardless of whether you change it or not, the audio quality is the same either way.
jdsmoothie is online now
post #3 of 5 Old 01-30-2013, 12:25 PM - Thread Starter
gazoo0000's Avatar
thank you for your input, much appreciated. My ps3 settings are all correct according to sony. The denon avr-791 shows pl2 cinema when everything is off (other devices e.g.. ps3, and samsung blueray player) When i turn on the ps3 the receiver switches to multi-channel in mode. My cable box is the only one that the receiver will playback in dobly digital. All devices are conected with HDMI to the receiver
post #4 of 5 Old 01-30-2013, 06:12 PM
jdsmoothie's Avatar
Liked: 7488
What settings exactly? When the 791 reads "Multi CH IN" it means the PS3 is set to LPCM. Reset the PS3 while connected to the 791.
post #5 of 5 Old 02-01-2013, 01:30 PM - Thread Starter
gazoo0000's Avatar
thanks for the info. i changed my settings from lpcm to bitstream in the ps3 and now i can get DTS-HD MASTER AUDIO !
Denon Avr 791 Receiver
