Pre/Pro suggestions? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 01-29-2013, 12:26 PM - Thread Starter
schwegs99's Avatar
My current setup is a 3.1 which consist of B&W 804s, CMC2 and a velodyne 12" sub (plan to upgrade CMC2 to a HTM3s and add a 2nd sub), then a Denon avr-3310ci with a NHT Power5 amp (200x5)
I'm looking to upgrade my AVR, but was wondering what would be the best around the $2-$3K range. I have seen Anthem MRX series, Integra 80.3, Denon avr-4520ci and etc.
Any thoughts or input?
schwegs99 is offline
post #2 of 8 Old 01-29-2013, 01:20 PM
Selden Ball's Avatar
Quoted: 3429 Post(s)
Liked: 1699
As best I can tell, all three are excellent. My impression is that the room equalization software used by Anthem is somewhat more awkward to use than Audyssey because it requires the use of a computer. (Although the extra-cost Pro version of Audyssey requires a computer, too). Note also that the Onkyo PR-SC5509 is functionally identical to the Integra DHC-80.3 at a somewhat lower price.
Selden
Selden Ball is online now
post #3 of 8 Old 01-29-2013, 03:43 PM - Thread Starter
schwegs99's Avatar
thanks.
what are you running?
post #4 of 8 Old 01-29-2013, 06:49 PM
Espo77's Avatar
Quoted: 182 Post(s)
Liked: 85
Just a little confused...are you looking for a preamp/processor or a receiver? Do you have a separate power amp?
Espo77's living room equipment: RECEIVER: Yamaha RX-A3030- SPEAKERS: Boston Acoustics M350, M25 center, surrounds, and front heights-
BLU-RAY: Oppo BDP103D- SUBWOOFER: HSU VTF-15H MK2- dedicated circuits for A/V- TV: Vizio P55C-1
Auralex Acoustics LENRD - Auralex Acoustics Roominator
Espo77 is offline
post #5 of 8 Old 01-29-2013, 07:59 PM
Legairre's Avatar
Quoted: 695 Post(s)
Liked: 357
Over the past 12 yrs I've owned the following pre/pros like: Sherwood P965(SNAP), Rotel RSP-1066(no room correction), and Marantz AV7005(Audyssey MultEQ XT), and receivers like the Denon AVR3300(no room correction), Pioneer Elite VSX-92TXH(MCACC) and now Anthem MRX300(ARC).
ARC is a bit different than Audyssey, MCACC ,YPAO etc... because you load the ARC software on your laptop and connect the mic to the laptop or PC and then the laptop is connected to the receiver. While the others use the receiver to do all the measurements ARC's uses your laptop to do all the measurements and then after you are satisfied with your graphs you upload the result to the receiver. You can also make changes to the results as many times as you like and see the results in the graphs on your laptop and then just upload them without running the measurements again. Of all the ones I've owned the Sherwood P965 and the Anthem MRX300 are the best sounding units I've used as a pre/pro in my room with my amps and speakers.
To my ears ARC is the most impressive room correction I've heard in my room with my gear. After having ARC I can't see myself buying anything again without it. I didn't know much about ARC before buying the MRX300, because it was previously only offered in Anthem's expensive pre/pros, so I just never read about it because it was in units out of my price range, but now I'm completely sold on it.
"What do you mean it's too loud? My ears aren't even bleeding yet!"
Legairre is online now
post #6 of 8 Old 01-30-2013, 08:55 AM
Liked: 1699
thanks.
I currently have a Marantz AV8003 driving a (5 channel) Marantz MM9000. Their new AV8801 is tempting, but has a list price of about $3600. frown.gif
The receivers he mentions all have preamp outputs, so they can be used as pre/pros, driving external amps
Selden
post #7 of 8 Old 02-02-2013, 10:10 AM - Thread Starter
schwegs99's Avatar
i have a 200x5 amp. looking for a pre/pro or avr.
post #8 of 8 Old 02-02-2013, 12:46 PM
Espo77's Avatar
Quoted: 182 Post(s)
Liked: 85
Do you want serious audio quality, or more of the bells and whistles?
Kind of like "do you walk to school, or carry your lunch?"
Espo77 is offline
