Pioneer VSX-822-K settings/volume - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 01-29-2013, 06:33 PM - Thread Starter
jproy12's Avatar
Hey everyone, new to the forum, I'll take the time to go introduce myself, but in the meantime I had a couple questions.
I just got a Pioneer VSX-822-K, which is powering Polk Audio RM6750 speaker and subwoofer. I am trying to find a way to make my "centre" speaker a bit louder, since like in this thread: http://www.avsforum.com/t/1423957/pioneer-vsx-822-volume I hear more of the outside noises and music than the actual voice.
Is there a setting for this? An option? On a related note, what kind of settings should I be looking at, this is my first "home theater" system you could say.
JP
jproy12 is offline
post #2 of 10 Old 01-29-2013, 06:51 PM
GaryWA's Avatar
Quoted: 16 Post(s)
First run the MCACC setup using the microphone on a tripod. Then if the center is still too soft, manually change the output level of it.
GaryWA is offline
post #3 of 10 Old 01-29-2013, 07:18 PM - Thread Starter
jproy12's Avatar
I've ran the MCACC setup on a tripod, and I find that the center speaker is still too soft for my taste. I'm just not sure where to adjust the level output of the center speaker, other than changing the distance for the speaker.
If someone could let me know where I can find these settings in the VSX-822-K, that would be great!
JP
jproy12 is offline
post #4 of 10 Old 01-30-2013, 12:37 PM - Thread Starter
jproy12's Avatar
Anyone else could help me out?
jproy12 is offline
post #5 of 10 Old 01-30-2013, 01:25 PM
GaryWA's Avatar
Quoted: 16 Post(s)
Hey didn't see you replied.
Go to your menu and it should be under manual SP set, and then go to channel level.
GaryWA is offline
post #6 of 10 Old 01-30-2013, 04:32 PM - Thread Starter
jproy12's Avatar
Thanks! That worked perfectly, didn't see that option.
JP
jproy12 is offline
post #7 of 10 Old 01-30-2013, 04:45 PM
jproy13's Avatar
Liked: 26
Great name!
jproy13 is offline
post #8 of 10 Old 01-30-2013, 05:57 PM - Thread Starter
jproy12's Avatar
Originally Posted by jproy13 View Post
Great name!
Been using this forum name for the past 6yrs, on various forums!
jproy12 is offline
post #9 of 10 Old 03-18-2013, 03:51 PM
jaymcd0626's Avatar
Can you share what you ended up setting your speakers settings to. I have the same Receiver and speakers.
thanks
Jay
jaymcd0626 is offline
post #10 of 10 Old 04-04-2013, 11:42 AM
AntonioZeped's Avatar
Just press the Receiver button at the top of the remote, then press CH select at the bottom of the remote, then choose the Centre channel and quickly press the + bottom below.
AntonioZeped is offline
Pioneer Vsx 822 K 400w 5 Channel A V Receiver Network Ready Pandora Ipod Iphone Black , Polk Audio Rm6750 5 1 Channel Home Theater Speaker System Set Of Six Black
