No sound to tv from onkyo receiver - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-30-2013, 07:46 AM - Thread Starter
tcl1's Avatar
I need some help! I'm not the most sound savvy! I am trying to connect my TCL tv to my onkyo receiver. The only output from the tv is a spdif. The receiver has two optical coaxials and one digital. I bought a digital coaxial cable and connected it to the tv and receiver and no sound. (Yes, I made sure it was on the right channel!) I also turned the speakers off on the tv through the menu and still no sound. I tried the second coaxial spot and no sound either. I'm sure there is probably a simple solution, but I have no idea what it is! Help!
tcl1 is offline
post #2 of 5 Old 01-30-2013, 09:21 AM
kkpro's Avatar
Quoted: 138 Post(s)
Liked: 76
The Onkyo probably has assignable inputs. Did you enable the audio out on the TV? Does the TV have a "variable" audio out (even with the internal tv speakers turned off, you can control the volume with the tv remote.)
kkpro is offline
post #3 of 5 Old 01-30-2013, 02:21 PM - Thread Starter
tcl1's Avatar
I have searched the tv menu for enabling the audio out and it does not have a setting for audio out. All the other "plugs" are inputs only on the TV;( If it helps the receiver is a DS484.
tcl1 is offline
post #4 of 5 Old 01-30-2013, 06:03 PM
JChin's Avatar
Quoted: 374 Post(s)
Liked: 210
Hi tcl1, Onkyo DS484 default to analog connection so you need to assign it to digital Coaxl 1 or Coaxl 2 or OPT.
Select your input (DVD, CD, Video 1 or 2), then hold that input button for about 2.5 second, then press that input button again repeatedly to cycle from Analog to OPT to Coaxl 1 to Coaxl 2.
JChin is online now
post #5 of 5 Old 01-30-2013, 08:22 PM
Espo77's Avatar
Quoted: 182 Post(s)
Liked: 85
You're not giving enough information as to what equipment you are using. The receiver is a "docking station" for your devices, like a Blu-Ray Player and a set top box...(cable or sat.). Where do you get your TV signal from..a cable box? If so HDMI "out" of the cable box to "in" on the receiver, then "out" of the receiver to "in" on the TV. You can connect two "outs" from the cable box...one to the TV and one to the receiver. This will allow you to watch cable without having to turn on the receiver, if that is what you want to do.
Espo77's living room equipment: RECEIVER: Yamaha RX-A3030- SPEAKERS: Boston Acoustics M350, M25 center, surrounds, and front heights-
BLU-RAY: Oppo BDP103D- SUBWOOFER: HSU VTF-15H MK2- dedicated circuits for A/V- TV: Vizio P55C-1
Auralex Acoustics LENRD - Auralex Acoustics Roominator
Espo77 is offline
