bi-amp - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-30-2013, 01:00 PM - Thread Starter
probman's Avatar
Would anyone like to state an opinion either way re. Bi-amp new speakers?. Hooking up new def tech sm55 with Yam 673 amp.
probman is offline
post #2 of 5 Old 01-30-2013, 01:22 PM
WagBoss's Avatar
bi-amping doesn't do anything. your receiver is limited by the power supply, not by the channel output. technically the way receivers do it is called bi-wiring. bi-amping does do something, but you need 2 amps
WagBoss is offline
post #3 of 5 Old 01-30-2013, 03:26 PM
raaj's Avatar
Quoted: 98 Post(s)
Liked: 133
I personally bi-amp my speakers and feel that they sound pretty good. Haven't tried traditional way, so can't for sure tell if there was an improvement with Bi-amping. There is a large contingent of prominent audio gurus saying bi-amping using a single receiver does not achieve much benefit, and would need a separate amplifier per channel set you are trying to amplify independently. I do it anyway because I have amp channels to spare, and nothing more to lose than paying for an extra pair of speaker cables.. smile.gif
raaj is offline
post #4 of 5 Old 01-30-2013, 03:44 PM - Thread Starter
probman's Avatar
The replies are great and love the input
Thanx!
probman is offline
post #5 of 5 Old 01-30-2013, 06:38 PM
JHAz's Avatar
Quoted: 305 Post(s)
Liked: 271
actualy, because the tweeter only gets maybe 25 percent of the power anyway, biamping can't increase available power enough to make more than a decibel of difference. And if you're not clipping, you won't hear a difference between biamped and non biamped. That said, I biamped my Sonus Fabers and my Magnepans and everything worked dandy.
JHAz is offline
