Accessing Denon1912 from wired and wireless devices - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-30-2013, 08:40 PM - Thread Starter
HiFr's Avatar
I have a Denon 1912 that is connected to my network using power line adapters. It works fine, I can stream music, etc. The airplay works when I use my computer that is on the network through a wired connection. However, it does not work when I use wireless devices (iPhone, Laptop). Also, the iPhone Denon Remote App cannot detect the receiver. Any help will be greatly appreciated.
HiFr is offline
post #2 of 4 Old 01-31-2013, 02:57 AM
jdsmoothie's Avatar
Quoted: 12452 Post(s)
Liked: 5690
jdsmoothie is online now
post #3 of 4 Old 01-31-2013, 09:05 PM - Thread Starter
HiFr's Avatar
I cannot see a solution to my problem in your link.
HiFr is offline
post #4 of 4 Old 02-01-2013, 03:36 AM
jdsmoothie's Avatar
Liked: 5690
Did you look only or did you try them as they will generally resolve the issue you're having with the Airplay icon not showing up on the phone or PC.
