harmon/kardon AVR 10 - phono preamp issues - AVS Forum | Home Theater Discussions And Reviews
Old 01-31-2013, 05:51 PM - Thread Starter
mattcook888's Avatar
hi all,
I recently purchased a harmon/kardon AVR 10 amp, which has no phono stage.
No problem i thought... ill just hook up my phono preamp, however i get nothing when i connect it. The preamp is a pro-ject audio systems 'phono box'. I have tested the preamp, aswell as the record player on another system and they work prefectly. I am also certain that all the inputs on the AVR 10 are fully functional, as i have tested them all with other input devices with no issues.
does anybody know of any reason the harmon/kardon avr 10 would NOT support a phono pre-amp for some reason?
thanks
mattcook888 is offline
Old 01-31-2013, 08:23 PM
Espo77's Avatar
Quoted: 179 Post(s)
Liked: 84
Originally Posted by mattcook888 View Post
hi all,
thanks
Can you describe how you have it all hooked up?
Espo77's living room equipment: RECEIVER: Yamaha RX-A3030- SPEAKERS: Boston Acoustics M350, M25 center, surrounds, and front heights-
BLU-RAY: Oppo BDP103D- SUBWOOFER: HSU VTF-15H MK2- dedicated circuits for A/V- TV: Vizio P55C-1
Auralex Acoustics LENRD - Auralex Acoustics Roominator
Espo77 is offline
Old 02-01-2013, 09:03 AM - Thread Starter
RC cables coming out of the record player are hooked into the INPUT of the preamp, RC cables coming from the OUTPUT of the preamp are connected to the INPUT of my amp. Also as i said this works, hooked up the exact same way(with the same record player) on a different amp.
