Help with Jamo mpa-101 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 02-01-2013, 06:07 AM - Thread Starter
dbaughn's Avatar
I have just installed the following system and believe i may have burned up my amp. If any one has any thoughts on where i went wrong please advise. I have 6 zones of 8 ohm sononce speakers for a total of 12 speaker in my house. each zone is wired with a four conducter wire from my media closet to a impemdence matching volume control in each of the 6 zones and from the 6 diffrent volume controls to each set of speaker in that zone. i wired all of the speaker home runs (4 conducter wire) together in the media closet and pigtailed off of that in to a Jamo mpa-101 amplifier that is connected to a sonos connect as the only source. all of the wires are in parrallel so +6 reds _6 blacks on right side and left side +6 whites and -6 greens then went into the amp. the amp shows to be 2x50 watt 4ohm and 2X100 watt 8ohm. i went with this amp because of lower cost and fiugred i would not be running more than 2 or 3 zones at any given time.
Thanks for any assistance you may provide.
I posted this in the 2 channel forum but no repsonse maybe someone here has some insight.
dbaughn is offline
