Marantz SR-5001 + Emotiva XPA or Upgrade to 2011-12 Receiver now and add Emotiva XPA later - AVS Forum | Home Theater Discussions And Reviews
View Poll Results: Keep Marantz SR-5001 and add Emotiva XPA, or upgrade to a recent model receiver now and add Emotiva
Keep Marantz SR-5001 and add Emotiva XPA-2/XPA-3 1 100.00%
Upgrade to a 2011-12 year model receiver now and add an Emotiva XPA amp later 0 0%
Voters: 1. You may not vote on this poll
post #1 of 3 Old 02-01-2013, 11:18 PM - Thread Starter
raaj's Avatar
Quoted: 185 Post(s)
Liked: 181
I currently have a 6-year old Marantz SR-5001 powering a modest 2 channel setup (Selah Audio SA-1 monitors). I will be adding a sub soon. I have been toying with ideas of upgrading my receiver to bring it up to speed, and have gone through a Denon 3313 (that didn't work out for non-qualitative reasons), and am now trying a Marantz SR-5007.
I have not been totally satisfied with the sound out of the new Marantz after Audyssey setup. I had a lingering feeling that the older SR-5001 sounded better - more open than the SR-5007. The primary reason for upgrading the receiver was to gain more HDMI inputs, room correction, and networking features. I also have an Apple TV, and a PS3 so, many of the networking features on the receiver are available elsewhere in a non-elegant manner. Now I discovered that the receiver is only recommended for 6-8 ohm speakers, and lower impedance loads while not recommended, may provide moderate performance.
This had me wondering if I could/should repurpose the same $$$ to buying an Emotiva XPA-2/XPA-3 and use the Marantz as a pre-pro, with a HDMI switch to add the required inputs. If I ever buy better speakers down the road, I don't want to limit my choice by having to rule out < 6 Ohm speakers, or anyway have to upgrade the receiver anyway at that point. But going this way, I would be missing out on Audyssey room correction functionality.
confused.gif What would be your preferred way of tackling this?
raaj is offline
post #2 of 3 Old 02-01-2013, 11:22 PM
XStanleyX's Avatar
Liked: 1270
I'd go for a receiver with Audyssey and add an amp later. I'm running a Marantz 7005 and it sounds as good as any receiver I've owned in the past. I've owned a bunch. You have to get Audyssey set up correctly for the best sound. If you're only going to use it for 2.1 I'd stick with what you have and add the sub first and an amp later if you feel you need it.
XStanleyX is offline
post #3 of 3 Old 02-02-2013, 02:47 AM
jdsmoothie's Avatar
Quoted: 15366 Post(s)
Liked: 7516
The first thing to do would be to determine if you truly do not prefer Audyssey or you simply haven't done the setup as effectively as possible. Please review the Audyssey 101/FAQ Guide linked in my sig to learn more about Audyssey and how to set it up properly. Also, many coming from an older model receivers note the bass isn't as powerful (due to bloated bass from their older receiver) and that the AVR isn't as loud at a given master volume setting as their old receiver. Audyssey sets the "reference" volume to 80/0db which is more than 3/4 of maximum due to using a logarithmic scale whereas older receivers used a linear scaled and may have only needed to be set to at most 1/4 of maximum for the same volume.
jdsmoothie is online now
Emotiva Xpa 5 5 Channel Power Amplifier
