Onkyo HDMI Failures - Page 9 - AVS Forum | Home Theater Discussions And Reviews
 24Likes
post #241 of 293 Old 08-20-2014, 04:19 AM
CherylJosie's Avatar
Quoted: 732 Post(s)
Liked: 297
They All Fail IMO
I called Onkyo customer service last year and explained that I had several failed receivers and complaints all over the Internet about this problem. I asked the very nice woman to please send email up the chain of command notifying Onkyo that their poor HDMI reliability was seriously damaging the brand.
I asked them to consider revising the HDMI thermal management. Perhaps they finally got the message, perhaps not.
My recommendation is that only an experienced DIYer should attempt this repair at home.
The repair procedure for the HDMI includes traditional static precautions as well as shorting two leads on the HDMI with a jumper to protect the board from static damage when it is removed. Apparently (my guess) there is a pin somewhere on a chip that has no static protection clamps in the pad ring (where the wirebonds connect the package pin to the die) and that pin will blow out if mishandled. Most likely the static protection was omitted to reduce input or output capacitance...
...at least that was what my employer did on one in-house custom IC design.
The Onkyo HDMI boards are difficult to remove. Several screws come out and then the cables must be removed appropriately or they will break. The release tabs must be pushed on the ribbon cable or the socket will cut the leads off the cable, and the flex strip has to be pulled out carefully with tweezers.
The connector sockets between the HDMI and its perpendicular interconnecting board along the side of the receiver are very tight. They have to be nudged apart with a screwdriver then carefully disconnected from each other by wiggling and pulling very hard at an angle to avoid shredding components that interfere with pulling straight.
The point is, replacing these HDMI boards is not for the novice technician. However, for an experienced repair person the procedure is relatively straightforward.
I bought a TX-SR606, TX-SR607, 2x TX-NR609, TX-SR705, TX-SR706, TX-NR929 all used.
Apparently the reason they were for sale is they were already failing.
All of them have failed HDMI except the TX-NR929 that was 'refurbished', probably less than 3 years old (my main receiver), and the TX-SR705 that had no sound output or video at all (I returned it).
All the HDMI failures were in evidence when I bought the receivers, but usually intermittent, especially once they warm up. None of the ones I tried out before buying showed any obvious failure but several began failing within hours of installation and one that had non-obvious symptoms started failing hard but intermittently within a couple of months, indicating the failures were all intermittent at first, developing slowly, and almost certainly known to the prior owner even though no one informed me the receiver they were selling had known issues (yes I did ask).
Perhaps one or two sellers had no idea but I doubt it. The main failure mode is lack of onscreen menu and video upscaling. These sorts of failures are hard to miss, especially when the onscreen menu suddenly stops displaying.
Repairing the HDMI board is another matter than replacing it. Good soldering skills are required as well as a knowledge of troubleshooting and not all the failure modes are the same, although cooked capacitors is the predominant failure mode especially in the newer models. The TX-SR705(?) and other similar models in that generation have both audio and HDMI failure modes that require adding a retrofit daughter board to repair it and are not worth the bother.
I have repaired the TX-SR606 and everything but the upscaler and menu are working now (maybe I blew the susceptible pin by not shorting it because the technical repair bulletin said nothing about it, or maybe the instructions I found on the Internet omitted some capacitors on the power supply for the upscaler that also seems to handle the menu that can be displayed in SD). Of the rest, only the TX-NR929 has no apparent HDMI failure yet and it is not 3 years old yet.
In the process of looking for solutions I found that there are some Youtube videos demonstrating a DIY repair and some Ebay vendors selling HDMI repairs for specific models at $75 and up plus shipping (different vendors come and go).
I also noticed numerous receivers listed on Ebay and Craigslist and Fixya etc. of many additional models disclosing HDMI failure including one that was only a processor with no amp or tuner. From this fact I speculate that all Onkyo models are susceptible and will fail eventually with enough hours under power unless some actual modification is added to protect them from heat.
The failure is due to excessive heat on the HDMI PCB. The DSP and HDMI etc. chips on the board have no heat sinks so they are actually using the entire PCB itself as the heat sink, meaning the heat is dumped into all the cooler running components on the PCB. Most likely IMO, the processor and HDMI chips that Onkyo used is an older (cheaper) larger dimension transistor IC technology with more transistor capacitance and higher aggregate switching dissipation than the board can safely handle.
The capacitors are only rated at 85C for 1000 hours (~40 days) so of course they eventually dry out and the power supply gets dirty. Then the digital communication starts getting bit errors and HDMI crypto key check starts failing, freezing all protected content intermittently. Eventually it will not sink up even in standard definition unprotected content and video screens of digital white noise start showing up while it tries to re-synch to the bitstream, then the video eventually fails entirely, especially the on-screen menu and upscaler that seem more sensitive.
Even when the amp is idling and the output stage is cool, even when there is no signal connection at all, the HDMI is pouring heat out through the vents in the lid.
Updating the design with newer, lower dissipation ICs and intelligent power management should eventually fix the issue for Onkyo in the newer models. I doubt they have any incentive to use heat sinks on the board or higher temp rated capacitors due to cost. When millions of units are in production over a decade, pennies count against the profit margin.
You get what you pay for and Onkyo has the best function/price ratio of any brand I know but probably the worst reliability as a result. Sony is relatively inexpensive too, but appears to have power amplifier failures and I do not like their feature set so I never bought one.
These descriptions of HDMI failure are all independent research and subjective observations on my part but I feel confident in my analysis.
I am still in the process of repairing the rest of the intermittently failing receivers. I expect my TX-NR929 will start failing within the next two years at which point I will have to repair that one too.
Only the Onkyo design team will know which of their products have been updated with lower dissipation chips and power management. If they keep putting more DSP into the board they might never fix the problem because they might just keep adding complexity and eating up the margin they gain back from other improvements. Only time will tell.
For now my recommendation is anyone who expects to keep their next receiver for more than 3 years should buy a Denon or Marantz or other model besides Onkyo that includes the best implementation of Audyssey room correction that one can afford. I am not impressed with the features and/or cost of other non-Onkyo brands (although I have little experience with them) but I do feel that Audyssey calibration is essential and unparalleled.
I also recommend that anyone with good electronics skills who has a need of many receivers at absolute bargain basement cost should buy used Onkyo (print this comment and use it to negotiate aggressively on price) and repair the HDMI as a DIY using the official Onkyo HDMI repair bulletin for the TX-SR606 as a rough guide (it has been leaked to the Internet) except ignore the directions to add a small ceramic bypass capacitor in parallel with the electrolytic because the problem is not effective series resistance but actual electrolytic capacitor failure.
I caught on to the HDMI failure after my second (no-test) used purchase of the TX-SR606 and chose to repair that one myself rather than return it because new prices and used competitor prices were just way too high for my plans. I used capacitors from my junk box that were probably 50 years old plus higher (12V) voltage rating and they have worked fine for over a year now but they are physically huge compared to the original surface mount. They needed to be laid sideways against the board and they needed longish wires to connect them but they still worked fine so I know the problem is not related to effective series resistance in any way, at least on on the five capacitors I replaced (the Onkyo bulletin only mentioned 4 but the Youtube video showed 5).
The solution is to replace (at least) all the power supply filter electrolytic capacitors possible (especially the surface mount 100uF 4V power supply filter capacitors) with leaded, high temp (105C for 1000 hours at least) capacitors. Use leaded capacitors and cut the leads long, bending the capacitor over if necessary for physical clearance, to keep the heat conductance to a minimum. Surface mount are in close contact with the PCB. Leaded capacitors can be positioned so that they are far enough away to avoid getting too much heat conducted into them. Convection and radiation will still warm them up but at least they will not be piping as much heat straight into the package through the leads.
If buying new, there is the possibility of mounting fans to the underside of the top lid so they can blow directly down onto the HDMI board whether the internal fans are present and running or not. That should work to prolong the life of the HDMI. Another solution is to glue heatsinks onto the hotter chips (be careful when feeling them because some get really hot and can burn you). Either modification will void the warranty so there is risk either way. Maybe wait until the warranty expires but then you risk protecting a board that is already on the verge of failure. Both these modifications are illustrated in posts here at AVS forum. Just search Onkyo HDMI.
I do not recommend buying the extended warranty on any electronic product as a general rule because on average the cost of the warranty on an expensive product just covers the cost of repairs but you pay in advance. Onkyo does repair many of these units, even some older models, but the repairs take a long time and requires moving the receiver. Instead of warranty I recommend putting the extra money into a reliable competitor's product and tossing it or dumping it on Craig's List when it eventually fails.
For the average person I definitely advocate doing your research first and then buying the best product you can manage rather than just going by maximum features for the lowest price, unless you are one who is constantly chasing the bleeding edge and will trade up in 3 years or less. No one wants to mess with failed equipment unless, as I mentioned, it can be had very cheaply and repaired very easily by a customer who already possesses the skills.
Please keep in mind that some Onkyo models such as the TX-SR606 usually had the HDMI failure within one year and the warranty replacement board also usually failed within one year. The failure rate of any model depends largely on whether the unit is installed in a cabinet with poor ventilation, whether other equipment or books and newspapers get stacked on top of it, whether it is placed on carpet and the bottom vents blocked/insulated by the pile of the carpet etc. so the more you do to keep the unit cool the longer it will last.
I do not have any direct knowledge of the reliability of the latest HDMI boards from Onkyo. We will have to wait and see. I do not trust any statements from the manufacturer.
That is the best I can do with this issue. Good luck.
old corps and supercell like this.
CherylJosie is offline
post #242 of 293 Old 08-20-2014, 06:40 AM
splatee's Avatar
Quoted: 30 Post(s)
Nice write up CherylJosie........
I just had to take my tx-nr709 in for HDMI failure. Lucky me though i still had 6 days left on my warranty
I took a look at the HDMI board and it is very different than the 606 HDMI board so when it fails again (hopefully not) i will attempt the capacitor fix, but not sure because of lack of info on the 709. I am going to install a fan inside the unit to help keep it cool. I run it all day long with my projector set up. I think i would mount the fan so it sucks the heat out instead of blowing on the HDMI board.
splatee is offline
post #243 of 293 Old 08-20-2014, 09:52 AM
cablebandit3's Avatar
Quoted: 23 Post(s)
Make sure your cabletv feed is grounded somewhere. Mine is NOW grounded at the splitter as it comes into the crawlspace but I am convinced that this is where the voltage spike is coming from that has killed an onkyo 3007 3x...3010 1x and a denon x4000 1x and an old dlp tv hdmi port 1x.
cablebandit3 is offline
post #244 of 293 Old 08-20-2014, 11:03 AM
dgater's Avatar
Liked: 36
Onkyo USA Support Information
08/19/2014 Loss of Audio/Network Connection Customer Care Program
As part of our commitment to quality and customer service we have determined that a limited number of Onkyo Brand receivers manufactured between 2009 and 2012 may experience loss of audio or loss of network connection. This malfunction has been traced back to a defective network chip.
We deeply regret any frustration or inconvenience this situation may have caused.
To address the problem and help people who may have an impacted receiver, Onkyo is launching a special Customer Care Program to remedy this issue for those receivers that may be affected by this loss of audio/network connection issue. This program has three steps:
1. Verify if your Onkyo receiver is impacted
2. Decide how you prefer to address the issue
3. Send us your receiver in a prepaid box and label that we will provide at no cost to you
As part of this program we are also extending our standard limited warranty period to cover this issue for affected receivers through December 31, 2018. All other terms, conditions and limitations of the original limited warranty shall continue to apply for the duration of the original standard limited warranty.
Importantly, please note that the loss of audio/network connection issue will not result in harm to any connected components or speakers since the issue is contained to a single element within the affected receivers.
To determine if your receiver is eligible under this Customer Care Program please click here
Loss of Audio/Network Connection Customer Care Program for US and Canada customers
We thank you for your loyalty!
Onkyo again apologizes for any inconvenience this may cause and will provide this repair as expeditiously as possible.
Onkyo is finally stepping up to the plate!
dgater is offline
post #245 of 293 Old 08-20-2014, 12:01 PM
J-e-L-L-o's Avatar
Quoted: 17 Post(s)
My Onkyo SR607 finally died on me. Numerous issues throughout the years. But once I set it and forget it..has been pretty faithful. Especially at heating my room lol.
I finally upgraded components, new 60in smart tv, tower speakers, and feeding my tv DLNA. The Onkyo wasn't doing what it was supposed to do. After I finally got everything working after hours of fiddling with it, I went through the menus to change some hdmi settings. Clicked one option, and the whole screen went into snow. Then...no video output.
It's not worth fixing. Buy something else instead. I actually had a failed board that shorted on me less than 2 years from buying it. Here it is 6 years later and finally bit the dust. I picked up a Sony open box STR-DH750 7.2 4k bluetooth receiver for $230 bucks that sounds amazing and doesn't even get hot when I put my hand on top.
RIP Onkyo
I will never buy another one. Lets see how my Sony holds up with a 2year warranty / 4 year extended.
J-e-L-L-o is offline
post #246 of 293 Old 08-20-2014, 12:27 PM
audio4life's Avatar
Liked: 300
Cheryl, I have been researching this to fix an Onkyo, and also saw about the static precautions but no procedures to do this. Do you have any idea how to do this and/or which 2 leads on the HDMI should be shorted?
audio4life is offline
post #247 of 293 Old 08-29-2014, 05:41 AM
rprice54's Avatar
Quoted: 94 Post(s)
Liked: 45
Did you guys see two posts up? Onkyo is repairing these, check out the link and mail it in. They took my refub 3007 which was a replacement for my original 3007 that died.
rprice54 is offline
post #248 of 293 Old 08-29-2014, 05:47 AM
turnne1's Avatar
Quoted: 1969 Post(s)
Liked: 481
2009 manufactured and newer
Warren
Rm 1 Samsung 65KS9800 Marantz 8802A prepro Sherbourn 5/1500A amp B&W CM10s..CM2 center...CM5's.rears
Rm 2 Vizio P50 Denon 4520 Celestion 305 speaker system
Rm 3 Panasonic 50ST50 Denon4520 Kef 2005.2 speaker system
Rm 4 Samsung 55KS8000 Pioneer SC95 Mirage Omni sat speaker system
turnne1 is online now
post #249 of 293 Old 08-29-2014, 08:38 AM
audio4life's Avatar
Liked: 300
Thank you, the 906 I have was acquired used and I didn't hear about the Onkyo offer until after I had ordered parts. I got the Unit for free, the owner was up front about the HDMI issues. Anyway I removed the HDMI board and replaced 13 caps, plus added 6 more across regulators and now the 906 is flawless. Probably cost me less than shipping the unit to Onkyo, about 40 bucks(I bought a soldering iron too).
post #250 of 293 Old 08-29-2014, 09:50 AM
zeus33's Avatar
Quoted: 1549 Post(s)
Liked: 1393
Did you post your repair process somewhere with pics? That would be very useful info to members not covered by warranty or the repair program.
pb940072 likes this.
zeus33 is offline
post #251 of 293 Old 08-30-2014, 01:20 AM
RailgunCD's Avatar
I've just had my second failure from my 5008, naturally, just 3 mo outside of its normal warranty. Unfortunately, living in the UK, Onkyo here isn't the same as Onkyo in the States. I'll be calling he shop I originally purchased it from to see what can be done, referencing the Onkyo USA extended warranty of course.
RailgunCD is offline
post #252 of 293 Old 08-30-2014, 09:24 AM
audio4life's Avatar
Liked: 300
Nope, there are currently 3 such in the HDMI repair thread which I used. 2 are 876 repairs and one is a 855 processor. They use the same daughterboard as the 906, so it's all good! Plus there are a few videos posted on youtube, and though they are not the same board, the procedures and techniques are the same.
post #253 of 293 Old 09-01-2014, 05:09 AM
Quoted: 23 Post(s)
my repaired 3010 definitely runs cooler....Im not sure what they changed in the hdmi section but there you go
post #254 of 293 Old 09-06-2014, 06:17 PM
solidscooter's Avatar
AMEN!! A $10 Holland Coax ground will do awesome things for buzzing in your system. At least in mine it did. And power issues, but I guess I didn't get mine hooked up soon enough.
I haven't seen much about Onkyo's lower end products on the thread, so I'd thought I'd post my experience so far.
I bought a AVX-290 HTIB online (refurb) and it was awesome until tonight. Having the HDMIs go out in the middle of the game is... well, less than ideal.
I have about three inches of space between the unit and the shelf above (obviously no other components stacked), but not much room to the left or right. Boy did it get hot before the ports failed. Actually it's weird, mine won't give me video out, but for some reason the audio is still coming in fine through all the HDMIs. It's only when I turn the TV (or my projector) on that the HDMI indicator flashes, then goes solid, and that's when I lose audio and no video.
This is the really interesting/annoying part. Called Onkyo, was surprised they had someone working on the weekend. It's still under the 1 year regular warranty that came with it, so the repair should be covered according to the support guy that didn't seem interested in my problem. He gave me the name of a place in Ausin (I'm in Waco, so short drive) to take the receiver.
I found their website, scrolled to the list of vendors they do work for, and found this beside the Onkyo logo:
"We know their receivers inside and out. We no longer do warranty work for them, but out of warranty we can help. If you have an HDMI problem, you probably have a bad circuit board, which we will not be able to order. Please contact K-O Electronics in Plano if you have an HDMI problem."
So it looks to me like this place got annoyed (or wasn't cost effective) replacing HDMI boards and stopped their in-warranty support for Onkyo. This is a clear testament to the problem... that is still clearly occurring. Apparently this place (Pyramid Audio) is a big center that does warranty stuff for every vendor you can think of. One of eight "Denon Super Service Centers" in the USA.
This is 2014, and even though my unit is refurb, it's still recent. I have no idea on when it was actually for sale new, but certainly not more than a few years. So I guess I'm taking it up to Dallas sometime this week. It blows.
Call me an idiot, but why isn't there a fan(s) in these receivers?? I have loved reading through this whole thread and people talk about putting a fan here or there, cutting a hole in my cabinet here, etc etc. I guess the day of use and throw away products is here to stay. I sternly believe there is no reason any consumer should have to leave a FOOT on all side of the receiver for ventilation, in the case of the Denon products. That is the most absurd thing I've ever heard. That pretty much restricts you to a rack in a closet somewhere, not in a normal TV stand like 98% of America has.
solidscooter is offline
post #255 of 293 Old 09-06-2014, 06:50 PM
DocCasualty's Avatar
Quoted: 195 Post(s)
Liked: 2377
Which receivers? My 609 has a fan and I believe that whole line does. I don't know anything about their HTiB offerings though.
Clearly Onkyo has a problem. Many of their receivers run hot and the HDMI boards fail. As posters report failures even with meticulous external cooling, I'm not convinced fans alone are the answer. It appears to me that the components and how their boards are constructed are the issue, with heat playing some role, no doubt.
I'm glad they are stepping up to the plate as far as the out of warranty repairs. I really like their products and hope they come up with a long term solution to the problem. I know my receiver will eventually die another death and I'd like to keep Onkyo in the short list for replacements.
"Dave, this conversation can serve no purpose anymore. Goodbye."
DocCasualty is offline
post #256 of 293 Old 09-06-2014, 09:50 PM
audio4life's Avatar
Liked: 300
Two things. First, you didn't have anywhere near enough space around the Onkyo. You knew enough to check for heat, and found plenty but didn't do anything about it? I'm surprised Onkyo is willing to cover unit abuse. Second, Onkyo gave you a warranty depot contact, which is pretty good for a weekend. Yes, the place is no longer handling Onkyo, but all that means is phone Onkyo back up and say you need another warranty depot. And at the end of this adventure, you'll want to not let ANY receiver run hot. They will malfunction over time.
post #257 of 293 Old 09-06-2014, 10:03 PM
First, it's been noted in this thread that the problem with the HDMI card would occur no matter the ventilation situation, as its a design flaw. Second, how is Onkyo supposed to define 'abuse'? If their units are overheating, they have no way (or reason) to test for 'abuse', especially if the 'abuse' is happening because a flaw in their design.
You'd think a competent company would know who they're paying to do their repairs. I called Pyramid before they closed today and they told me they haven't been doing in-warranty repairs for a long time.
Oh, and for fun I measured. It's five inches. Woopie
post #258 of 293 Old 09-06-2014, 10:05 PM
Mine doesn't... so the more you know I guess...haha! I didn't know other Onks had them
post #259 of 293 Old 09-06-2014, 11:18 PM
audio4life's Avatar
Liked: 300
It's not clear whether the HTIB unit is part of the extended warranty, it's a recent model, so I don't think it is part of the defective HDMI boards. Onkyo is not going to define 'abuse' very closely as they are trying to make amends. But I'm defining that sticking a receiver in a tight shelf with closed rear and sides, and only 3(okay, 5 then) inches of space on top is abuse. Checking for heat and finding plenty was the warning sign that the unit was too hot. I had an excellent Sony blu ray player that I put on top of an HD PVR, it ran hot, and in 2 years cooked the Sony model which had no record of HDMI issues on line.
Sorry to pick on you, but I suspect that any brand you would have put in there would have failed within a couple of years.
Edit: You're mistaken about the units failing no matter the ventilation situation. I've owned an Onkyo 876, which was covered by this new warranty, for almost 6 years. It's not given a hint of trouble because 6 months in I read about Onkyos running hot and some placing fans on top to remove the heat, which is what I then did. Cost me about 25 bucks and it's been the best insurance I ever bought.
slimm likes this.
post #260 of 293 Old 10-02-2014, 12:28 PM
RailgunCD's Avatar
So as a follow up, seems my HDMI board wasn't the issue this time. The dac board according to the company was the issue. Seems sketchy.
post #261 of 293 Old 12-03-2014, 10:35 AM
MontyInNJ's Avatar
Just did the HDMI repair process on a 3009. After they got the unit, turned it in 4 days. Monty
MontyInNJ is offline
post #262 of 293 Old 03-07-2015, 11:26 AM
RailgunCD's Avatar
So I got mine back about two months ago and it's still not right. HDMI sync issues, odd delays with on screen display things, such as volume changes taking 30 seconds to appear on screen after adjustments have been done and the mute indication on the top left instead of bottom right. And network functionality is bunk. What a pita.
post #263 of 293 Old 03-09-2015, 05:48 AM
htpcforever's Avatar
Quoted: 493 Post(s)
Liked: 191
It was a specific chip on the HDMI board that handled Ethernet, Dolby codecs, and DTS codecs and was made by Texas Instruments.
htpcforever is offline
post #264 of 293 Old 09-11-2015, 04:37 AM
Liked: 0
Just picked up a TX-SR309 for free... all working perfectly.... for the moment!
Reading this thread I have to say I'm shocked at such shoddy engineering.
1) According to Onkyo the "affected" units were made before 2012. 2012!!!! The problem of BGA chips cracking their solder "balls" first came to large prominence in about 2006/2007 with multiple failures on things like graphics cards, XBOXes, laptops (yes even Apple MacBook Pros had this problem). To be still designing products with this issue in 2011 is scandalous.
2) My 309 CAN have a standby power consumption of 31W (I've read of 150W for some other AVRs). This is just powering the HDMI circuitry for things like passthrough and CEC control. 31W!!!! That means that if there are 2 chips powered up to do this, they are each consuming maybe 15W a piece. Any chip consuming that much DEMANDS a heatsink. Every laptop CPU has one, every desktop CPU has one, every GPU has one. Many of these consume less than that. It's crazy to expect these chips to survive without a heatsink! Remember that's just on "standby", what do they consume when they are actually doing work!?!?
My solution?
I don't know, but it will certainly involve heatsinks and fans (probably ducted).
This is clearly an example of PLANNED OBSOLESENCE. Yes these units are designed to fail. So perhaps I shouldn't be so surprised after all...
torrent99 is offline
post #265 of 293 Old 09-11-2015, 05:10 AM
Tiptx's Avatar
Quoted: 36 Post(s)
Liked: 24
Run
I don't care what brand you go with someone is going to find problems out with whatever brand or however much you spend. Now with Onkyo from all the different post about this brand I would stay away from them as far as I could until I have some sort of guarantee that this issue can be resolved in a timely matter or just completely fixed.
Tiptx is offline
post #266 of 293 Old 09-11-2015, 05:35 AM
wtxgringo's Avatar
Quoted: 53 Post(s)
Liked: 64
Sent my 818 in mid Aug for no sound issues & probs with the Net function, got it back Tues & so far so good. No more hiccups with the Net function either. No complaints for now.
"To the journey..."
Sony KDL60W630B; Onkyo TX-NR818
Polk RTi A7 Mains; Polk RTi CSi A6 Center; Polk RTi A5 Wides & Surrounds
HSU VTF2-Mk4, Dish Network 722k, Iogear WiFi Hub
Teac PD-H600; Marantz BD7004;
Orbit TT Red Plinth, Acrylic Platter, Ortofon OM 5E Cartridge
wtxgringo is offline
post #267 of 293 Old 01-26-2016, 09:35 PM
Liked: 0
Originally Posted by wiz561 View Post
I was wondering if anybody had any problems AFTER they did they repair or had it returned to them. I picked up my receiver last week, plugged it all in, and no sound. Great video, just no sound. I ran through a bunch of things, and I couldn't get sound working. The list of things included a factory wipe and audyssey setup. BTW, audyssey and the tuner work, just not audio over HDMI.
I know, it's been a while. But I thought I'd let you know that this happened with my TX-NR807, too. But in this case, things went a different route altogether, then: After returning the receiver immediately to the (official) repair shop as dead-on-arrival, they've sent me an email. Basically they were saying that "other parts" are at fault which are "not covered" by extended warranty. They will not fix my 807 they said, then tried to sell me a TX-RZ800 instead.
So, I sent my receiver to an official repair shop, for a repair procedure covered by extended warranty. Yet somehow, they managed to turn my 807 into a 20kg doorstop. And now, after having demonstrated their stunningly magnificent level of ineptedness, they expect to take my money next. Like, what the... ?!
I got so aggravated about this #@!, I wrote a VERY polite letter (old fashioned paper thing) directly to Onkyo Corporation's Mr. Otsuki in Japan, and furthermore contacted Onkyo Pioneer Europe. They are "looking into it now".
niston is offline
post #268 of 293 Old 01-28-2016, 06:44 AM
DrBilly2's Avatar
Onkyo HDMI Failure
I sent mine in for repair, under warranty, and within 6 months, it failed again. Now, no warranty and company tried to sell me a new unit somewhat discounted. I said no thanks and bought a Pioneer Elite instead. Too bad that they had this problem, but their customer service really missed the boat.
DrBilly2 is offline
post #269 of 293 Old 02-07-2016, 08:59 AM
FiremanFrank's Avatar
My TX-NR818 just failed this morning and I have had an Elan Z powered fan sitting on top of it since I purchased it. It made it just over 2 years and I am not sure if my Square Trade warranty or sending it back to Onkyo is the best answer. Either way it sucks that it failed on super bowl Sunday.
I hope Onkyo has finally gotten this HDMI failure under control as I will likely buy another brand next time to avoid the headache.
FiremanFrank is offline
post #270 of 293 Old 02-07-2016, 10:11 AM
jkust's Avatar
Quoted: 21 Post(s)
That's a bummer...I'd send it back to Onkyo for the repair I think because from the two times they repaired mine so far, it came back quickly. Both my loss of internet connection and the HDMI failed within the same week but the warranty site didn't allow me to select two failures and so they fixed the loss of internet connection and I assumed they'd just do the other HDMI fix, but they didn't and so had to go through the whole process again....a bummer because my whole house audio plus the 5.1 system runs on the 616. Still to this day, comparing a 4 year old 616 to much more expensie AVR's ignoring things such as atmos that didn't exist, the 616 still has features I can't get on much more expensive AVR's as backwards as that seems to me. Powered Zone 2 WITH the ability to control volume AND a zone 3 for a few hundred bucks is crazy.
jkust is offline
Onkyo Tx Nr818 , Onkyo Tx Sr806 Receiver , Onkyo Tx Sr608 Receiver
