Is YPAO Worth it? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 02-03-2013, 12:00 PM - Thread Starter
H.D.T.V's Avatar
Thinking of upgrading my RX-V371 to the 373. Only thing I gain is OSD and YPAO calibration.
Is YPAO worth it? I mean does it provide a better listening environment?
H.D.T.V is offline
post #2 of 12 Old 02-03-2013, 12:07 PM
javygonx's Avatar
Quoted: 99 Post(s)
Liked: 27
If you sell the 371and get sme money to get the 373 then maybe. Otherwise both receivers are very similar then its not worthy.
javygonx is offline
post #3 of 12 Old 02-03-2013, 01:57 PM - Thread Starter
H.D.T.V's Avatar
Anyone else?
H.D.T.V is offline
post #4 of 12 Old 02-03-2013, 03:18 PM
postrokfan's Avatar
Quoted: 521 Post(s)
Liked: 3109
The simple answer is yes. Room correction like YPAO should make your listening experience better depending on your speaker configuration and room environment.
Living Room: B&W 804D, B&W CMC S2, B&W ASW610, Yamaha RX-A2030, Rotel RC-1570, Rotel RB-1582 mkii, Oppo BDP-93, ATV.
postrokfan is offline
post #5 of 12 Old 02-03-2013, 07:44 PM
Kilian.ca's Avatar
Liked: 37
The benefit of room correction depends on the room and the software. YPAO isn't considered the most sophisticated room correction scheme here. If you're upgrading take the opportunity to consider other options within your budget.
Audiosceptics accept audio trials using 25 people. A recent Oxford study with over 353,000 patient records from 639 separate clinical trials shows for every 1,000 people taking diclofenac or ibuprofen there would be 3 additional heart attacks, 4 more cases of heart failure and 1 death every year.
Kilian.ca is offline
post #6 of 12 Old 03-23-2013, 01:58 PM
mnc
mnc's Avatar
Quoted: 543 Post(s)
Liked: 469
Which EQ setting do most prefer: Flat, Front, or Natural?
NHT speakers, Denon 4520, Panasonic 65VT50, DUAL PSA XS30SE's
mnc is offline
post #7 of 12 Old 04-01-2013, 09:55 PM
SARHENTO's Avatar
I prefer FLAT for the reason given in the manual.
SARHENTO is offline
post #8 of 12 Old 04-03-2013, 04:29 PM
mnc
mnc's Avatar
Quoted: 543 Post(s)
Liked: 469
I've been experimenting lately and without a doubt Flat sounds best. What's strange is, it's the only way I get good bass out of my speakers. Very strange since I thought YPAO didn't do any bass eq.
mnc is offline
post #9 of 12 Old 04-03-2013, 04:37 PM
SARHENTO's Avatar
Of course it does bass EQ. I wonder where others got the idea that it does not. The parametric EQ shows the graphs for all your speakers including your sub after running YPAO
SARHENTO is offline
post #10 of 12 Old 04-04-2013, 07:00 AM
SAVholic's Avatar
I prefer Natural with my old RX-V1800, to my ears it sounds "richer" than Flat.
"My English is not very good looking" - Celia Cruz
SAVholic is offline
post #11 of 12 Old 04-06-2013, 07:17 AM
mnc
mnc's Avatar
Quoted: 543 Post(s)
Liked: 469
In my post ypao graph it shows no adjustments below 110Hz.
mnc is offline
post #12 of 12 Old 08-12-2013, 11:43 AM
mnc
mnc's Avatar
Quoted: 543 Post(s)
Liked: 469
I now use Front eq and so far I like it the best.
mnc is offline
