newbie question- Sony HTIB speakers with Denon 1713 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-03-2013, 11:32 AM - Thread Starter
tallmike's Avatar
Hi,
First of all I must say that I am a noob to AV receivers and speakers. Recently I bought a brand new Denon AVR 1713. I also had a old set of Sony HTIB speakers and they marked 2.7 ohms.
I connected Front L&R and center to Denon 1713. After Audyssey setup, here is the parameters set by 1713.
Speaker config:
Frone: large
Center: Small
Levels:
Front L: -2.0 db
Front R: -2.5 db
Center: -4.5db.
Speakers worked so far however I heard that those speakers might damage my Denon receiver.
Is my setup ok? Will my new receiver survive those HTIB speakers?
tallmike is offline
post #2 of 3 Old 02-03-2013, 03:34 PM
jdsmoothie's Avatar
Quoted: 14321 Post(s)
Liked: 6761
At average (normal TV level) listening volumes you should be fine, however, if you raise the volume too loud, the AVR will shut down in protection mode before it is harmed.
jdsmoothie is online now
post #3 of 3 Old 02-03-2013, 06:42 PM - Thread Starter
tallmike's Avatar
good to know my limits. I will be careful before I upgrade to some "real" speakers.
tallmike is offline
