Need some help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 02-03-2013, 07:31 PM - Thread Starter
menace2society's Avatar
I'm trying to choose between the onkyo tx-nr3010 and the tx-nr5009 they will be powering klipsch rf7II in a 5.2 setup with hight speakers in a room that's 14x24x10. There is about a $50 difference between them with the 5009 being the most expensive. All opinions appreciate.
TIA: Menace
I'd rather give you $10 than 10 minutes. I can always earn $10, where do I go to earn 10 minutes.
menace2society is offline
post #2 of 7 Old 02-03-2013, 08:11 PM
wlhungdude's Avatar
Quoted: 189 Post(s)
Liked: 237
is there one certain feature that is swaying your decision?
mods, can we have a 'dislike' button ?
wlhungdude is offline
post #3 of 7 Old 02-03-2013, 08:22 PM - Thread Starter
Not really. That's why I'm stuck I have a $1600 budget, and want to upgrade from my tx-nr3007 that went belly up, warrenty company decided not to fix it so they refunded the cost. I liked the 3007 so I figured I'd like the new ones. But I have no brand loyalty .
TIA:Menace
post #4 of 7 Old 02-03-2013, 08:54 PM
wlhungdude's Avatar
Quoted: 189 Post(s)
Liked: 237
I'd go for the 3010. Mainly for the HDMI issues ... between those 2.
And I come from a similar position... my 707 died 2 weeks ago, and I've been laboring over decisions... up to the Denon 4520,... but I think my sweet spot is the 818. For me, Audyssey XT 32 is a must, as well as dual HDMI out, and pre-outs. In the current O line-up, nothing higher up is worth the extra $$, to me. YMMV
Joseph
have you called Onkyo? They do have a "trade-in" program for units "just out of warranty". I had no idea and had never seen mention of it, until I called... but I don't think they advertise it... wink.gif
post #5 of 7 Old 02-03-2013, 09:18 PM
Stephen Hopkins's Avatar
If you are doing 5.2 + Height (7 channels amplified) why not go with the NR818, NR1010 or other top-notch 7.1 AVR?
Do you have plans of adding more speakers in the future, or is there some other step-up feature you find critical in the NR3010? You have quite efficient speakers, so small differences in power shouldn't be a major driver in this class of AVR.
Stephen Hopkins is offline
post #6 of 7 Old 02-04-2013, 12:50 AM - Thread Starter
You never know what the future holds... That's why I believe it is better to have and not need then to need and not have. I don't want a AVR that is less then the one I had. Right now I'm using a tx-nr709 and I'm not satisfied, my system doesn't sound the same, the best way I can describe it is it sounds anemic. Like it need some vitamins or something. The sound is not as rich and full as it used to be. If it is true I would be interested in trading in my 709. It was a refurb I bought from A4L with a 5yr extended warranty, or try to sell it on eBay or something like that. Does anyone know if the 5009 will sound better then the 3010? For me sound key.
Thank:Menace
post #7 of 7 Old 02-04-2013, 11:41 AM - Thread Starter
No other advise? That's it. Help please
Menace
