I'd like to plug my headphones to my hdtv but it doesn't have a headphone jack - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-03-2013, 09:15 PM - Thread Starter
jerrycomo's Avatar
Like most flat screens, they don't have any.
Of course, I plugged the tv audio jack to a receiver and the receiver to my headphones (Grado).
I know electronic shops sell some cable so I can plug from the tv audio jacks
directly to the headphones, bypassing the receiver.
So,
Question 1:
What is the specific name of that cable?
Q2:
Which of the two choices provide the best audio quality, from the receiver or the store cable)?
Or should I get a headphone amp?
Thx guys, I hope I wrote in the correct audio thread.
jerrycomo is offline
post #2 of 3 Old 02-06-2013, 07:56 PM
JBWIII's Avatar
Liked: 43
What kind of TV audio jack do you mean? Most TVs these days have only a line-out audio jack, which means that it's a constant low-level signal.
You need some kind of amplifier (and volume control) between the TV and your headphones. Right now you're using the receiver. You could also use a dedicated headphone amp, but you need something more than just a special cable.
I don't know that the headphone amp will sound any better than your current receiver. What kind is it?
JBWIII is offline
post #3 of 3 Old 02-06-2013, 08:19 PM
afrogt's Avatar
Quoted: 1090 Post(s)
Liked: 782
Why would you want to bypass the receiver?
Afro GT
afrogt is online now
