Yamaha v473 questions and operations using YPAO - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-05-2013, 07:53 AM - Thread Starter
polymath's Avatar
Hey guys I have a question..I just purchased this receiver last week and I finally got the Yamaha v-473 all hooked up. Did the YPAO setup (which was really easy btw) and it looks and sounds pretty damn good...when the volume is cranked.
BUT...One question I have though. Yamaha receivers volume control start at like -80dB and go up to +16.5dB. Compared to my older Yamaha receiver (HTR-5650) which I believe has less power it seems like I have to turn the volume much higher to enjoy movies and tv. On the older receiver I regularly would have the volume at like -40dB on the receiver and with this new one the volume needs to be at around -20dB or higher to enjoy it.
I don't know if its the receiver, if its because of HDMI (older one was hooked via toslink) or what. Either way it makes no sense to me considering I am using the exact same speakers as before. Thoughts? Other than that the only difference is I used YPAO to setup this time instead of my radio shack spl meter.
polymath is offline
post #2 of 5 Old 02-05-2013, 02:48 PM
MitsMarty's Avatar
Check out the setting for the theme for the type of sound played there are about 15 choices which include dolby, 5 channels stereo, several theaters in Europe ect ect.. try to match then compare to what you were playing on old system
regards,
Marty
MitsMarty is offline
post #3 of 5 Old 02-05-2013, 02:55 PM
highdefav1's Avatar
Quoted: 106 Post(s)
Liked: 37
I wouldn't worry about what the volume setting was on the old receiver vs the new one.
I can tell you on my 673, I usually have it around -25 for movies, running MP in-wall/in-ceiling speakers and even then I'm told it's too loud and to turn it down a bit.
So I turn it down to -25.5.
Panasonic 55ST50
Yamaha RX-V673
Klipsch RF-52 II // RC-52 II // RS-42 II
Klipsch RW-12d
Klipsch KG 2.5
highdefav1 is offline
post #4 of 5 Old 02-06-2013, 06:43 AM - Thread Starter
polymath's Avatar
Anyone have any issues with YPAO and center channel being too low? I think this is the source of the problem. I can't hear the dialogue without cranking it up.
Maybe I should get out my trusty spL meter and see what happens then compared to YPAO?
polymath is offline
post #5 of 5 Old 02-06-2013, 08:46 PM
JBWIII's Avatar
Liked: 43
I have the same issue with the center being too quiet so I cranked it up. YPAO can do whatever it wants with its test tones but with movies, especially when you don't have any sort of audio volume compression on (which I have disabled on both my cable box and Blu-ray), home listening dialog will be too quiet since in the theater, sound effects can (and are supposed to) be earth-shattering when compared to voices.
JBWIII is offline
Yamaha Rx V473 Receiver
