Marantz SR5007 and Apple TV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 02-05-2013, 07:20 AM - Thread Starter
newavsbuddy's Avatar
Hi Friends,
SR5007 has Airplay but it's for music and not for the video. (if I am correct)
I want to know if Apple TV works with Marantz SR5007. OR Can I directly connect Apple TV to a projector?
Appreciate your reply.
Thank You
newavsbuddy is offline
post #2 of 6 Old 02-05-2013, 07:27 AM
XStanleyX's Avatar
Liked: 1270
Yes, it will work with that receiver.
XStanleyX is offline
post #3 of 6 Old 02-05-2013, 07:40 AM - Thread Starter
Thanks for the response.
Where can I connect Apple TV?
HDMI port on the back of the receiver?
post #4 of 6 Old 02-05-2013, 07:45 AM
XStanleyX's Avatar
Liked: 1270
Yes, one of the HDMI inputs on the receiver. It's a pretty cool device. You'll probably like it. It does not come with a HDMI cable in case you're not aware of it.
post #5 of 6 Old 02-05-2013, 08:07 AM - Thread Starter
Thank You. I have an extra high-speed HDMI cable that I can use.
post #6 of 6 Old 02-05-2013, 08:12 AM
XStanleyX's Avatar
Liked: 1270
I don't own one but my son does. He loves it. My favorite feature is using my iPod and Spotify via airplay. I pay 10 bucks a month for the higher bitrate. If you listen to a lot of music it's worth checking out. It will work with an iPad also if you have one already. Enjoy that Apple TV. smile.gif
Marantz Sr5007 Home Theater Av Receiver
