iPhone 5 to AV receiver - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-05-2013, 09:29 PM - Thread Starter
ltlredwagon's Avatar
Dang, I'm just not sure where to post this. Let me know if there's a better place.
There is a "lightening digital AV adaptor" for the iPhone 5 which enables one to go from lightening to HDMI. My AV receiver (Denon 2809) has several HDMI IN jacks and an HDMI OUT to an HD projector. So I was thinking I can just use an HDMI cable to connect my iPhone 5 to one of the HDMI IN jacks on the AV receiver, and watch anything that is viewable on the iPhone. Yes? No?
ltlredwagon is offline
post #2 of 3 Old 02-06-2013, 07:45 PM - Thread Starter
Heard from someone that it should work fine. Got the adaptor and, yes, it works perfectly. Helps me out as there is a place I go to in the mountains where I have no internet service except for my phone. So I can play Netflix, Hulu, etc. from my phone on a 100 inch screen. Not great quality, but, surprisingly, not so bad either!
post #3 of 3 Old 02-06-2013, 07:47 PM
bommai's Avatar
Quoted: 467 Post(s)
Liked: 142
In my opinion, a better solution would be to buy a $100 AppleTV, then use AirPlay or AppleTV's own Netflix app to stream. Then you can use your iPhone as the remote.
bommai is offline
