"OFFICIAL" Pioneer SC-1222-K Owners Thread - Page 16 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
Old 02-28-2013, 04:27 AM
GregLee's Avatar
Quoted: 862 Post(s)
Liked: 292
Originally Posted by jlm86 View Post
Since MCAAC does not EQ the subwoofer, do we just do a subjective EQ based on our desired output?
Maybe you're not distinguishing EQ from calibration? MCACC does calibrate the sub for amplitude and distance. It does not try to correct the subs' frequency response, other than by it's "standing wave" filters. There is no way for you to "do a subjective EQ" unless you buy outboard hardware that lets you alter the subs' frequency response. (Except that you could change the subs' crossover controls.)
Greg Lee
GregLee is offline
Old 02-28-2013, 04:59 AM
eyekode's Avatar
Quoted: 23 Post(s)
MCAAC: Stil not clear on the subwoofer configuration..
Some of the anti-MCAAC groups think this is big showstopper that the sub is not EQ'ed, but perhaps not, as Pioneer engineering is pretty good reputation, and i would think that if Audyssey XT32 is so great they might have included in their top units..
Trying to eq subs is interesting. In my room there are 12+ db valleys and 9 db mountains (with my original sub placement). My sub in isolation measures flat to 20hz (my own measured DIY design not manufacturers specs). Sure you could tune down the peaks easily but you can't boost the valleys by 12db. To truly fix sub frequencies you must fix the room.
That being said I do wish they would allow manual eq on the sub channel as I would use it for minor adjustments. Note I haven't really looked into the pio's sub tuning because I have been using a BFD for years.
Salem
eyekode is offline
Old 02-28-2013, 06:06 AM
okibcn's Avatar
Liked: 26
Advanced MCACC corrects phase, delay and level for all the spectrum. So it actually equalizes the sub too. Please do not make your assumption an urban legend because that is not true. It even allows you to fine tune the settings on MCACC to your own preference after calibration, Audyssey doesn't.
Regards
If this post has been useful to you please Thumb it Up!
·· AV System
Receiver: Pioneer SC-1222K
Spkrs: homemade monitors + Energy Take Classic 5.1
Display: Samsung UN55ES8000
Src: Comcast DVR / Apple TV 3 / Xbox360 slim / HTPC / AirPlay / Pandora / Bluetooth*
*Pre-processor: Noozxoide EIZO-rewire PRO
okibcn is offline
Old 02-28-2013, 06:14 AM
okibcn's Avatar
Liked: 26
Salem
Standing wave detection tries to fix those huge valleys and mountains that EQ can't fix. It may not fix the problem, but sure it is going to help.
Regards
·· AV System
okibcn is offline
Old 02-28-2013, 06:32 AM
tbooth's Avatar
Originally Posted by GusGus748s View Post
tbooth,
These are my Advanced Video Settings:
HDMI Color Depth: 8 Bit
HDMI CEC: Disabled
Forced DVI Output: No
Output Color Space: Auto
Default Decoder Color Space: Auto.
Thanks! I have my Dune set to these exact settings and I don't get output. Can you tell me exactly what HDMI cable you are using. I don't know what else to try except to take my receiver to a service center.
tbooth is offline
Old 02-28-2013, 06:36 AM
tbooth's Avatar
Originally Posted by okibcn View Post
Have you tried replacing the cable?
I've tried 5 different HDMI cables. A monoprice redmere slim cable, a brand new HDMI 1.4 cable, 3 random HDMI 1.3 cables I have laying around and a cable that came with my Dune.
tbooth is offline
Old 02-28-2013, 06:37 AM
okibcn's Avatar
Liked: 26
You had the same problem with an VSX receiver, isn't it? That means that probably it is your Dune and not your receiver the faulty device, even more when we know that both devices are compatible.
Regards
·· AV System
okibcn is offline
Old 02-28-2013, 07:52 AM
tbooth's Avatar
Regards
Yep, same issue with a VSX 1122-k.
tbooth is offline
Old 02-28-2013, 08:04 AM
Azurith's Avatar
I just got my 1222 from Newegg and am pretty impressed so far. Everything works as expected.
Do I get cultist robes and a ceremonial dagger when I join the club? biggrin.gif
Azurith is offline
Old 02-28-2013, 08:21 AM
JChin's Avatar
Quoted: 350 Post(s)
Liked: 204
Originally Posted by jdrhjr View Post
Sometimes it takes minutes to get a signal. I find that if I power on the source before I switch to the input on the receiver that I have a better success rate.
Hi jdrhjr, may I ask which source your that having the problem with? Or is it all sources?
JChin is offline
Old 02-28-2013, 09:29 AM
jdrhjr's Avatar
All sources. Once I get the picture going, I may or may not be able to switch to another source and still have a display. I'm tired of dealing with it. Sending it in for a refund today.
Thanks to everybody who tried to help. This just wasn't meant to be for me.
jdrhjr is offline
Old 02-28-2013, 09:53 AM
GusGus748s's Avatar
Quoted: 415 Post(s)
Liked: 700
All my HDMI cables came from Monoprice High Speed HDMI cable.
GusGus748s is offline
Old 02-28-2013, 11:12 AM
okibcn's Avatar
Liked: 26
HDMI implementations are not the same in all the brands. Some of them are very tight to the specs and some others allow timings and levels of the signal to have some more tolerance. The issue that you are describing seems to be related to an out of specs implementation in the HDMI of your Dune, so tight that most receivers won´t work while others may allow some out of spec signals. I´d change or at least test another Dune. You can go to Best Buy and test it really quickly. If it doesn´t work either, then you can return it. It might be a local incompatibility, but GusGus748s has your same configuration... working.
Regards
·· AV System
okibcn is offline
Old 02-28-2013, 11:20 AM
okibcn's Avatar
Liked: 26
Welcome to these forums and to the SC-1222K owners club! you just need to stop by here every time and so and help others!
Regards
·· AV System
okibcn is offline
Old 02-28-2013, 11:43 AM
JChin's Avatar
Quoted: 350 Post(s)
Liked: 204
If you try receiver reset, what procedure or how did you reset it?
Also try setting the receiver resolution from Auto to 1080/24p or 1080p.
JChin is offline
Old 02-28-2013, 12:27 PM
tbooth's Avatar
I performed my reset by turning the receiver off and then pressing and holding the "Enter" button on the front panel and turning the receiver back on. The receiver then displays "Reset < No >". You can then press the left or right arrow to select "Reset" and press enter.
tbooth is offline
Old 02-28-2013, 12:55 PM
jdrhjr's Avatar
This is what I did as well. It's what the rep from Pioneer told me to do. I didn't try setting the receiver to 1080p/24 because to be honest I didn't know how. I no longer have the receiver so I guess it's a mystery that will remain unsolved. Take care, guys.
jdrhjr is offline
Old 02-28-2013, 01:09 PM
SC1222Chicago's Avatar
I have a USB hard drive playing music question. Is there a way to get the receiver to play all sub-folders within a folder. So when I use the app on my phone I can navigate to a folder and play the songs inside the folder. I want to select for example a folder called Rock and play all the albums in sub folders underneath it. Also I broke off the front flip down door as I put the receiver in a cabinet and wanted to close the door with the USB drive connected. I bought a right angle USB connector off eBay and a hard drive that wakes on power.
SC1222Chicago is offline
Old 02-28-2013, 07:07 PM
bad1550's Avatar
Quoted: 56 Post(s)
Liked: 41
Just received my 1222 today and updated firmware and ran calibration. I am not getting my subs to work after calibration. I set the manual speaker settings to small.
How do I get the subs to work? Not sure which steps I missed
Thx
Edit
Seems to work when I turn up the volume to almost max. On my Onkyo 809 the volume on subs were much fuller at lower volumes
Is there a link to the proper sub calibration.
bad1550 is offline
Old 02-28-2013, 09:16 PM
javygonx's Avatar
Quoted: 100 Post(s)
Liked: 27
I have your solution. Check your inbox and try that setup. Them post your results.
javygonx is offline
Old 03-01-2013, 12:40 AM
GusGus748s's Avatar
Quoted: 415 Post(s)
Liked: 700
So far, I've had this receiver for 2 days. I haven't been able to fully test it. I tested my Dune D1 media player, and it worked without any issues. Thereafter, I upgraded to the latest firmware. I re-formatted my corsair 32 gb flash drive to Fat32 even though it was already Fat32 (recommended). Downloaded and unzipped the files. Hooked it up to the AVR, and approxiately less than 10 min. it updated.
I was surprised that it turned off and did not turn back on after the update. Yesterday, I download the iControlAV2012 app to my wife's and my iPhone 4s phones. At first I kept getting an error message "error code b47110." After some research, I found out that the iControlAV2012 app will not turn on your receiver unless you have NETWORK STANDBY ENABLED. After I enabled network standby, I was able to fully controlled the AVR. I also signed to my Pandora account via the AVR's OSD. Pandora is fully functional, and it sound awesome biggrin.gif
I will be off work this weekend, and I will try to run MCACC. I would like to also say that my new Polk Audio 25C sound AWESOME!!! I just need to raise my TV several inches since this speaker is pretty tall. I will be installing the iControl app on my wife's iPad. I also like the option that you can re-name the HDMI inputs! So far, I am very happy with this receiver. At first, I thought I was going to regret buying it.
However, it does sucks for those of you who have had issues with this AVR.
Old 03-01-2013, 01:53 AM
jlm86's Avatar
Quoted: 24 Post(s)
I have the weekend off too, and will be setting mine up to...
Q. My center channel sits below the TV and GusGus mentions raising his height perhaps, and i've always wondered about that, as dialog it seems is lost sometimes in that it is at knee level..(?)
Anyway, the more read about MCACC vs Audyssey etc, the more confused i actually get. My Onkyo Audyssey seemed good ,but maybe i need to give this a chance it don't concern myself with it.
The subwoofer EQ may not be such a big deal in long run perhaps...
**There also is a dedicated MCACC avs forum here that i just discovered...
http://www.avsforum.com/t/1112470/official-pioneer-mcacc-thread/3540
jlm86 is offline
Old 03-01-2013, 04:04 AM
bad1550's Avatar
Quoted: 56 Post(s)
Liked: 41
Thank you!
Bob
bad1550 is offline
Old 03-01-2013, 05:12 AM
chrisexv6's Avatar
Thx
Edit
It will be source format dependent as well.
When I first got my 809 the sub sounded very very weak. Turns out DTS format is mixed at a lower reference level than Dolby formats. The 809 allowed you to up the level per incoming format, the Pio does not.
Try a Dolby Digital (TrueHD, etc) track and see if the sub sounds louder. On my Pio it sure did...I have several DTS Master HD tracks, and 1 Dolby True HD. At the same vol level the sub sounded louder with the Dolby track.
chrisexv6 is offline
Old 03-01-2013, 05:22 AM
tbooth's Avatar
I wanted to thank everyone for their troubleshooting tips. I received the correct power supply for the Dune and it worked immediately after I plugged it in. The display on the front of the Dune is now much brighter as well. I guess it just wasn't getting enough juice. biggrin.gif
tbooth is offline
Old 03-01-2013, 07:39 AM
GusGus748s's Avatar
Quoted: 415 Post(s)
Liked: 700
Awesome news.
Old 03-01-2013, 02:09 PM
korkster's Avatar
Quoted: 48 Post(s)
Liked: 24
Thx
Edit
I'm wondering the same thing. With my old Kenwood, I barely had the volume a quarter turn. Now I have it cranked almost to max. I'm also hoping I'm plugged into the right output. The quick start guide shows subwoofer 1 but the av navigator showed it going into the zone 2 out which didn't make sense to me.
korkster is offline
Old 03-01-2013, 02:26 PM
korkster's Avatar
Quoted: 48 Post(s)
Liked: 24
I finally had a chance to set mine up today. It was delivered on Tuesday, but I was away on business. I've got a lot of tweaking to do, but have things working for the most part. I have a couple of concerns at this point in addition to the low subwoofer output.
I'm having issues with the remote. It controls the volume, and will change inputs, etc., but it won't open up the home menu nor control anything in the menus. I've had to do it all at the receiver. Is it a bad remote or is there some setting that needs to be addressed to give it full control?
Another issue is getting audio from tv to the receiver via optical cable. I'm sending audio, as well as video, directly from the cable TV box for watching TV, but I had been taking advantage of the smart tv features by sending audio back to my receiver via digital optical, and it worked fine with my Kenwood. I've got no sound with this, and I checked to make sure I reconfigured the input settings. Is there something I'm missing?
I'm a bit frustrated at this point. I didn't have HDMI capability with my old receiver, but I'm wondering if maybe simpler is better. Hopefully I'm just making some rookie mistakes with the set up so far.
korkster is offline
Old 03-01-2013, 02:34 PM
GaryWA's Avatar
Quoted: 16 Post(s)
You need to press the "RECEIVER" button on the remote to get to the settings.
For the optical, make sure you have your source on the AVR set to either TV or BDR depending on which optical port you used.
GaryWA is offline
Old 03-01-2013, 02:40 PM
okibcn's Avatar
Liked: 26
It couldn't be the receiver. Now you can enjoy the full potential of your system.
Congrats!!!
I recommend not using the AVnavigator. the PC version has some bugs, like that known bug in the sub connection. Use directly the manual. it is really good.
I do not have any problem with my bass, you must be missing something. Have you already calibrated the system with the Adv. MCACC?
I recommend connecting the TV only through HDMI and connect everything else to the receiver. nonetheless it will work if you connect both to the TV, Forget the optical link for audio. That was the past.
Regards
·· AV System
okibcn is offline
