"OFFICIAL" Pioneer SC-1222-K Owners Thread - Page 34 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
Old 06-15-2013, 09:06 PM
drawz's Avatar
Quoted: 23 Post(s)
Anyone measured idle power with a kill-a-watt?
drawz is offline
Old 06-15-2013, 10:56 PM
larkowski1's Avatar
I have a kill-a-watt, but my 1222 is on it's way from New Egg, so i won't be able to until about Thursday or so. My Denon 2312 was about 70 watts or so.
Panasonic P46ST30 | Denon AVR-X2000 | PSB T45/B15/C40 | Oppo BDP-83 | DirecTV
larkowski1 is offline
Old 06-15-2013, 11:19 PM
scoobdude's Avatar
Quoted: 59 Post(s)
Liked: 30
Not sure how accurate my ups is but it says 81 watts with the router, modem and led light on as well. TV and ps3 are on standby but those never register. But then again the LEDs, router and modem with everything else in standby say 18 watts. So again no idea how accurate that is.
scoobdude is offline
Old 06-16-2013, 09:55 AM
drawz's Avatar
Quoted: 23 Post(s)
Thanks for the info guys. Most of the energy consumed at idle is converted to heat. Trying to figure out what would work best in my mostly enclosed TV stand.
larkowski1 - keep us posted once your kill-a-watt arrives. I'd be curious to know the power consumption during standby, idle, moderate volumes, and at reference during a movie. The latter two measurements will depend on what speakers you have to an extent (more or less efficient will have an impact).
drawz is offline
Old 06-16-2013, 10:26 AM
goblue1's Avatar
It's an internal y splitter so it will only measure the distance of one sub. However it will help when out some of the nulls with the mcacc and help correct the delay
Will the avr recognize that there are 2 subs? Also, I turned the crossover dial on the back of the sub all the way clockwise to 200. Do I just leave the all-in-one crossover setting in the avr to 80?
I hooked them both up, but haven't had a quiet house yet (kids) to run another calibration. On my previous 10" sub it's volume in the avr set at -3.5. On my new 12" duals I've had to up that all the way to +5. Does that sound right?
goblue1 is offline
Old 06-16-2013, 12:36 PM
larkowski1's Avatar
I'm not waiting for the Kill-a-watt. I have that. I just ordered the 1222 from Newegg on Friday. It should be here Wednesday. I have a crazy work schedule this week, so I probably won't hook it up until Thursday evening/Friday morning. My speakers are PSB T45s which are 90 db efficient anechoic, so I've never had to turn my receivers up too far to get substantial sound smile.gif Regardless, I'll post my findings when I can. I'm also interested in standby and idle. I sold an Onkyo a couple years back because there wasn't significant difference between the two and you could fry an egg on the top in standby eek.gif
Everyone here says the 1222 runs cool, so I'm hopeful there will be good results.
Old 06-16-2013, 04:46 PM
jdbob's Avatar
62 Watts, 83VA (0.74 power factor)
With what for me would be a fairly loud movie scene the highest I saw it was 70W (95VA) but the Kill-a-Watt has a fairly slow response time.
jdbob is offline
Old 06-16-2013, 05:58 PM
kjohn's Avatar
Am I to understand that you can only upgrade the 1222k via the USB port or can you use the Ethernet port and do it via the internet? Also is the remote lighted.
KJ
kjohn is offline
Old 06-17-2013, 06:14 AM
eyekode's Avatar
Quoted: 21 Post(s)
With network standby and hdmi passthrough on I get 6.5w from my kill-a-watt meter. Turned on but not playing I get 61.6w. Playing music at moderate levels (too loud for talking, but not loud) I get 62.5w hehe smile.gif.
eyekode is offline
Old 06-17-2013, 07:33 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
You can do either way but latest firmware is not available via Ethernet upgrade method. You have to use USB method.
Foxbat121 is offline
Old 06-18-2013, 12:58 AM
Zap Branigan's Avatar
Has anyone been able to get the remote to control anything other than the receiver? I've had no luck with anything other than a Pioneer CD changer. No luck with my LG TV, Denon BDP or DVD players, Directv box, nothing. I used the codes provided in the downloaded manual.
Zap Branigan is offline
Old 06-18-2013, 03:46 AM
scoobdude's Avatar
Quoted: 59 Post(s)
Liked: 30
Yes I got it to control my Samsung TV. I was even asked to reprogram some of the buttons and such.
Old 06-18-2013, 03:49 AM
scoobdude's Avatar
Quoted: 59 Post(s)
Liked: 30
It will only recognize that there is a sub. Not the quantity. In regards to your volume, one thing you can do is run the mcacc volume with one sub and see the corrected volume. Then run the 2nd individually and adjust it till you get the same adjusted volume in mcacc. This week level match them at the listening position.
Old 06-18-2013, 09:57 PM
eyekode's Avatar
Quoted: 21 Post(s)
I went back and used an SPL meter. My mains are not sensitive and with 2 channel audio I couldn't get it over 70w when playing at an average of close to 90db at my seating location. I fully believe the 80%+ efficiency they claim for the class D amps.
eyekode is offline
Old 06-19-2013, 07:10 AM
drawz's Avatar
Quoted: 23 Post(s)
Thanks guys, very helpful. Need to remeasure my current setup before jumping ship.
drawz is offline
Old 06-19-2013, 07:17 AM
mbuck's Avatar
Quoted: 23 Post(s)
I can get the SC-61 for $600 but it's BB Magnolia's demo unit that's been on the shelf for almost a year. Still full warrantee.
What benefits do I get from the SC-61 vs. the same (actually a touch lower) priced SC-1222?
I've read through the forum and read some of the differences in terms of specs, but I can't tell what in use benefits the SC-61 would bring. The only one I can make it is it plugs into full home theater automation (speakers throughout the house).
Since you're all way more informed, would you worry about it sitting on BBs Magnolia theater? (not sure it got a lot of use since they usually were running there even higher end stuff)
mbuck is offline
Old 06-19-2013, 09:07 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
The differences are probably superficial: Elite badge and maybe different color on the display. The main difference is warranty. Elite models typically come with one extra year of warranty.
Old 06-19-2013, 09:56 AM
mbuck's Avatar
Quoted: 23 Post(s)
Would you worry about it being a shelf model? The good news is that it was in their Magnolia area so not a lot you can do to it.
mbuck is offline
Old 06-19-2013, 10:13 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
Theoretically, warranty period on the open box demo unit starts at the day they put on shelf. So, the only advantage of extra year of warranty may no longer there for you.
I'd pick the NeEgg deal over BB open box.
Old 06-19-2013, 10:26 AM
mbuck's Avatar
Quoted: 23 Post(s)
Ouch. One year off the warrantee, hat's a big deal. Thanks.
mbuck is offline
Old 06-19-2013, 05:44 PM
eyekode's Avatar
Quoted: 21 Post(s)
The Elite also has 12v triggers if that matters to you.
eyekode is offline
Old 06-20-2013, 08:04 AM
scoobdude's Avatar
Quoted: 59 Post(s)
Liked: 30
Best to check with pioneer but I think the warranty start from date of purchase.
Old 06-20-2013, 08:13 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
For most floor samples, no. But in practice, no one is tracking the date of opening for floor demo.
Old 06-20-2013, 11:56 AM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
According to Best Buy Customer Service the warranty start on THE DATE OF PURCHASE. I would suggest to getting an extended warranty as well.
GusGus748s is offline
Old 06-20-2013, 03:52 PM
MrEastSide's Avatar
Quoted: 25 Post(s)
Liked: 55
The warranty starts on whatever date is on your receipt. Period. Pioneer has no idea how long any unit may have been open and on a shelf for. All the receipt indicates is open box. It doesn't say, open box and used on a shelf for 11 months. It starts at the point you purchase the item.
That would be like buying a brand new car from a Ford dealer and the Ford corporation saying, well... the car was delivered to the dealership a year ago, and a few people test drove it, so we'll only be honoring two years of the three year factory warranty. It just doesn't happen that way.
Of course, I got it modified with the TK-427, which cheeks it up another, maybe, 3 or 4 quads per channel.
MrEastSide is offline
Old 06-20-2013, 05:45 PM
kjohn's Avatar
Got my 1222k but can not figure out how to show the GUI on my TV and how do you cut up or down individual speaks for the receiver HELP :-)
KJ
kjohn is offline
Old 06-20-2013, 06:11 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
Unfortunately. 1222 does not support OSD overlay. Use the calibration mic to perform an auto MCACC calibration. It will balance and EQ all your speakers automatically.
Old 06-21-2013, 09:24 AM
eyekode's Avatar
Quoted: 21 Post(s)
It does not support overlaying a video source but you can display the GUI on your TV. Just hook up your tv to hdmi out and hit the reciever button on the remote then hit the home menu button (also on the remote).
Salem
eyekode is offline
Old 06-21-2013, 09:03 PM
kjohn's Avatar
I can't get the artwork with steaming music via dlna is it possible ?
KJ
kjohn is offline
Old 06-23-2013, 07:42 AM
kjohn's Avatar
Anybody ?
KJ
kjohn is offline
