"OFFICIAL" Pioneer SC-1222-K Owners Thread - Page 52 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #1531 of 1535 Old 08-24-2017, 01:15 PM
Liked: 0
Hey, everyone.
I was hoping someone could help me. My Pioneer SC-1222-K receiver just stopped working for some reason. When I tried to turn it on nothing happened. I took the cover off and checked all of the fuses and everything is good. When I put the cover back on and plugged it back in I decided to hold the power button down and the unit turned on and displays 'POWER ON' although will not do anything else. If you hit the power button again it turns off but in order to turn it back on you need to hold the power button down for a period of time.
Any idea whats wrong? Is the receiver still salvageable? Not sure what to do and any help would be appreciated!
-Brenton
Brenton Watkajtys is offline
post #1532 of 1535 Old 08-24-2017, 02:19 PM
LastButNotLeast's Avatar
Quoted: 1792 Post(s)
Liked: 1403
Try a factory reset:
https://www.techwalla.com/articles/h...neer-receivers
Michael
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
Don't guess, measure: Getting Started With REW: A Step-by-Step Guide
LastButNotLeast is offline
post #1533 of 1535 Old 09-04-2017, 05:24 PM
Liked: 0
Ok im going nuts. I have a pioneer SC1222-K. Just had to send it in to get warranty work done and they reset to factory default. Since i got it back i have not been able to use the iControlAV app on my phone nor iPad. So ithought i would update it. There is an update. Now my issue is, the receiver wont recognise ANY usb i put in it as having the update file in it. And this update cant be done over the internet. Anyone have any ideas? All usb devices ive tried were empty with only the unzipped update file on it.
Sent from my SM-N920V using Tapatalk
regalscenter77 is offline
post #1534 of 1535 Old 09-04-2017, 05:41 PM
scoobdude's Avatar
Quoted: 59 Post(s)
Liked: 30
What format and what size is the USB?
For the app did you make sure you have it set to DHCP or in a range of statics that is available on your network? Also did you verify the network settings were turned on? Not sure how good you are with computers and bettering but there is a way to send commands via command prompt.
Sent from my Pixel using Tapatalk
scoobdude is offline
post #1535 of 1535 Old 09-05-2017, 10:20 AM
Liked: 1403
Try reformatting the USB drive to a different format (I almost went with "formatting format," but I think you know what I mean).
Michael
