Receiver help for my Infinity Primus 163's - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-06-2013, 07:11 PM - Thread Starter
zowzout123's Avatar
So the receiver I have now is the Yamaha HTR-6030 and I plan on using that for my computer setup and buying a new receiver for my home theater stuff. So with that being said, is there any reason this receiver wouldnt work well for the computer? Or is there a good, cheap alternative for the computer? (around $150?). I wont need it for much, just optical out I believe and 2.0 setup and maybe later upgrading to a 2.1 at the most on my PC.
On a related note, for my home theater setup, I also purchased the Infinity 363's and want to know whats a good receiver I can use for those? In the immediate future I see myself getting the PC351 center channel speaker and using a 3.0 setup with a good possibility of going to a 3.1 shortly after. That will be a 'for sure' thing (the 3.0). However, I could also really see myself going up to a 5.1 (Not any higher really, and if I do I will make the necessary changes then). So any help on finding a good receiver for this setup would also be appreciated.
I saw this one and was curious about it because the price was nice.
http://www.amazon.com/Yamaha-RX-V373-5-1-Channel-AV-Receiver/dp/B007JF8FD8/ref=sr_1_11?s=aht&ie=UTF8&qid=1360034944&sr=1-11
What will be hooked up to it would be my satelite TV and my PS3. I couldnt see myself needing more than maybe 3 HDMI inputs on a receiver. 4 wouldnt hurt but I doubt I would need that.
Thanks in advance!
zowzout123 is offline
post #2 of 4 Old 02-06-2013, 07:45 PM - Thread Starter
zowzout123's Avatar
So many people viewing this board in particular I figured it wouldn't take so long for responses to come in. =/ Was hoping to bounce a couple ideas around and research some tonight. Ah well.
post #3 of 4 Old 02-06-2013, 08:24 PM
afrogt's Avatar
Quoted: 1088 Post(s)
Liked: 782
That Yamaha RX-V373 will be perfectly fine for your needs.
So would this Pioneer
http://www.amazon.com/dp/B007O5ATC8
Afro GT
afrogt is online now
post #4 of 4 Old 02-07-2013, 07:03 AM - Thread Starter
zowzout123's Avatar
Thanks! Also here's is one other receiver I am interested in as well and would wonder what most people would get.
http://www.amazon.com/Onkyo-TX-NR515-7-2-Channel-Network-Receiver/dp/B0077V88VI/ref=cm_cr_pr_product_top
And, I found it as a refurbished item for $50 less and i'm wondering what the popular opinion is on refurbished items. Are they worth taking the risk on?
