First time buyer looking for advice - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-06-2013, 08:24 PM - Thread Starter
Backwoods56's Avatar
Hello,
I have been reading the forums for a while and finally decided to make an account in order to prepare for my first speaker purchase.
I was hoping that someone could point me in the right direction towards a receiver that would adequately power a BIC America Formula FH56 soundbar and eventually a sub woofer (most likely a PL-200).
My plan is to see what the sound is like with just the bar, then decide if a sub is necessary. Like I said below, I do live in an apartment - so I have a feeling that a sub would go to waste for the time being because I probably wouldn't be able to use it without grief from the neighbors.
Some information:
I live in an apartment and I am planning on using the system in my living room that is 15 x 12.
Here are some of my thoughts about the features I was looking for:
- 5.1 Channel would be sufficient
- Wired network interface might be nice for firmware updates but not a deal-breaker (I have zero interest in apps like pandora built into the receiver)
- Audyessy seems like it would be a nice feature to have - I don't plan on living in an apartment forever haha
- HDMI - looking for 4 to 5 HDMI ports
I think that about covers it.
I'm not really sure on a budget yet. I would like to try and find the best bang for the buck - a receiver with good build quality that will last.
Thank you!
Backwoods56 is offline
post #2 of 3 Old 02-06-2013, 10:46 PM
wlhungdude's Avatar
Quoted: 180 Post(s)
Liked: 223
hiya Backwoods,
now that that's out of the way... we really need a budget to make any recommendations. Even saying something like "bang for the buck" is too vague. Do you want to spend $200, $2000, or $20000 ?
There is a different "bang for the buck" answer for each... well, not really for the 20K.. at that point, it's just expensive eek.gif
mods, can we have a 'dislike' button ?
wlhungdude is offline
post #3 of 3 Old 02-06-2013, 11:00 PM - Thread Starter
I would like to keep it around $350ish if that helps.
