echo sounds from the reciever - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-06-2013, 11:05 PM - Thread Starter
sputty's Avatar
I have a new pioneer reciever. When i try most of the advanced surround modes when watchimg a movie ii get this annoying echo sounds from the dialougs of the men at the movie.
When i use the standart surriund mode it sounds good.
Am i doing something wrong? Need to configure something different at the reciever?
sputty is offline
post #2 of 3 Old 02-06-2013, 11:17 PM
jevans64's Avatar
Quoted: 208 Post(s)
Liked: 162
Some of those modes, like Stadium, etc. have intentional delays to create an echo effect on purpose. I wouldn't use any of those unless that is the desired sound you want to achieve from your material. I generally only use these modes for 2-channel music. You'll want to stick with either a Dolby Digital ( DD ) or Digital Theater Sound ( DTS ) mode for movies. If you are still getting an echo with these modes, then the imaging ( speaker delays ) are off. If the Pioneer has an automatic room correction test you can run, I would run that first. At the very least, the room correction would balance the output over all speakers and set up the delays correctly based on where you place the testing mic.
Denon AVR X7200WA, Emotiva XPR-5, Emotiva XPA-7, Sony XBR 75" 850C, Oppo UDP-203, Roku Ultra.
DefTech BP7000SC (L/R), CLR3000 (C), SM55 (FH), UIW BPZ/A (SB), UIW 75 (TM).
JBL L7 (Sur), EoSone RSR 350 (RH).
PC 2.1 setup. Emotiva Stealth 6, SVS SB16-Ultra sub, Emotiva DC-1 DAC.
jevans64 is offline
post #3 of 3 Old 02-06-2013, 11:36 PM - Thread Starter
sputty's Avatar
Thanks for the quick reply! i will try to reconfigure the delays and stick with the standart surround modes...
sputty is offline
