Turn off or mute "clicking" noise receiver makes when chaning audio listening modes - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 02-07-2013, 07:13 PM - Thread Starter
burnsey23's Avatar
If I am changing the TV channel between an HD channel and SD channel and the audio on the receiver goes from Dolby Digital to Stereo, my receiver makes a click sound. Is there a way to turn this off or mute it? It is annoying when channel surfing.
I have an Onkyo TX-SR503 receiver. It is connected to my tv via an optical audio cable.
burnsey23 is offline
post #2 of 9 Old 02-07-2013, 07:25 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
Nope. At least mine doesn't. Maybe if you check every menu....I couldn't find it on my HTRC370 in any case plus I've read of many that do this (believe it is the sound of a relay). Just stop watching the stuff with poor audio and video...SD? Why? wink.gif
lovinthehd is offline
post #3 of 9 Old 02-07-2013, 07:35 PM
primetimeguy's Avatar
Quoted: 556 Post(s)
Liked: 359
No, that is just how Onkyo's work.  It is switching the amp section off/on when changing input types and sources.
primetimeguy is offline
post #4 of 9 Old 02-07-2013, 07:50 PM
tsaville's Avatar
Quoted: 163 Post(s)
Liked: 299
My Onkyo 3008 clicked when I did almost anything (pause/fast forward on the DVR, mute, input change, etc). In my experience, Onkyo and Denon are the biggest offenders on the excessive clicking. My Yamaha is dead silent except when powering the unit on/off. I had just assumed that ALL receivers clicked, so it was a pleasant surprise. biggrin.gif
tsaville is offline
post #5 of 9 Old 02-08-2013, 03:50 AM
Theresa's Avatar
Liked: 51
My Denon rarely clicks if at all. My Onkyo frequently clicked.
Theresa is offline
post #6 of 9 Old 02-08-2013, 08:15 AM
tsaville's Avatar
Quoted: 163 Post(s)
Liked: 299
My cheapo 1612 is the loudest clicker I've ever heard, although it does it less frequently than the Onkyo. Perhaps it is more subdued on the higher end Denons (I believe you have the 4311).
tsaville is offline
post #7 of 9 Old 02-08-2013, 12:33 PM
Theresa's Avatar
Liked: 51
I have the 4520. It does click for a few operations but not nearly as frequently as my 5508.
Theresa is offline
post #8 of 9 Old 02-08-2013, 12:37 PM
kbarnes701's Avatar
Quoted: 6740 Post(s)
Liked: 5069
The clicking is the noise made by the nice mechanical relays Onkyo use. If they used cheap solid state relays there would be no audible clicking. The relay activates when you change sound programs - eg from Dolby 5.1 to Stereo etc. One way to minimise it is to make these changes less often. A way to do that is to set up the AVR so that all sources use whatever you prefer all the time - eg DD 5.1 always defaults to DD 5.1 PLIIz or whatever, 2.0 channel always defaults to DD 5.1 PLIIz and so on.
kbarnes701 is offline
post #9 of 9 Old 02-18-2015, 06:21 PM
Liked: 0
If I am changing the TV channel between an HD channel and SD channel and the audio on the receiver goes from Dolby Digital to Stereo, my receiver makes a click sound. Is there a way to turn this off or mute it? It is annoying when channel surfing.<br>
I may have a solution. Try leaving your satellite or cable station on an analog station and selecting a listening mode other than "Direct". I like THX Cinema. Then change the channel to something digital and set the listening mode to the same, or I like Dolby. My "clicking" noise was immediately gone when channel surfing or an analog commercial interrupts your HD programming. Hope this helps others. I have an Onkyo TX-NR616.
kipster319 is offline
