Sound cutting out - why?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-09-2013, 08:58 PM - Thread Starter
olfac87's Avatar
I was watching a blu ray (Dark Knight Rises). About 2/3 through the main speakers started turning off. The center and rears seemed to have no problem. I paused the blu ray player for 5-10 seconds and then hit play again. The main speakers would come back for a short amount of time (30 second to 2 minutes) and then cut off again. Pause, play, sound, no sound...rinse and repeat.
My setup:
Oppo 103 --> Marantz SR5007 --> Krell KAV-250p (home theater bypass) --> Bryston 9B-SST --> PSB Synchrony One towers
Any ideas? My system is new to me (less than a week old all put together) so any help would be appreciated. I will cross-post this to a few other places.
olfac87 is offline
post #2 of 5 Old 02-10-2013, 05:01 AM
Quoted: 75 Post(s)
Liked: 113
First, check your cables. Also try setting the Oppo to output pcm instead of bitstream.
rnatalli is offline
post #3 of 5 Old 02-10-2013, 05:24 AM - Thread Starter
olfac87's Avatar
Thanks. I will look for this setting in the Oppo. Is there any hit to performance by changing this?
olfac87 is offline
post #4 of 5 Old 02-10-2013, 06:38 AM - Thread Starter
olfac87's Avatar
Update: I checked the cable connections and changed to LPCM. The sound cut out almost immediately. I also changed discs (put in Terminator 2). I put the Oppo back to "Auto" for the HDMI audio. The only other change I made was setting my center speaker to SMALL on the Marantz. I was able to watch about 45 minutes of Terminator without any sound disruptions. Still waiting to see if this holds. Except the only change I made at this point was on the Marantz.
olfac87 is offline
post #5 of 5 Old 02-21-2013, 05:04 AM - Thread Starter
olfac87's Avatar
Update #2: It looks like it was the Marantz. I hooked up speakers directly to the FL/FR Outputs (instead of running the mains through the Krell) and with both my Oppo and older DVD player the sound cut out to the mains after a certain amount of time. Marantz was great, giving me a return authorization and a new unit is on its way. We'll see if it solves the problem.
olfac87 is offline
