Harmon Kardon AVR 225 buzzing ?! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 02-11-2013, 09:05 AM - Thread Starter
jazzgtrl4's Avatar
Hi new here to the forums. I have an older HK AVR 225. It has this intermittent buzz when cold it buzzes pretty loud for awhile then goes away after awhile. Or sometimes comes back. I thought i read somewhere that its the video card or something like that and if you disconnect it the buzzing stops. Where is that located on this receiver? does anyone have a picture? i think its just a ribbon cable connected somewhere. thanks!
Todd
jazzgtrl4 is offline
post #2 of 7 Old 02-11-2013, 11:44 AM
M Code's Avatar
Quoted: 717 Post(s)
Liked: 419
Todd
Clarify the condition..
Is the buzz coming through all speakers?
Is the buzz level controllable by the volume control?
Is it a mechanical type buzz/vibration?
Post back some your response and we will advise more later..
M Code is offline
post #3 of 7 Old 02-11-2013, 11:52 AM - Thread Starter
jazzgtrl4's Avatar
HI thanks for the reply
Yes the buzz comes just through the front L and R speakers, that is all i have hooked up. Thats all i use it for, no video etc..
No the buzz just stays at one constant level. like bees, buzzing. no vibration..i guess once it warms up it goes away. thanks for your help
post #4 of 7 Old 02-14-2013, 08:51 AM - Thread Starter
jazzgtrl4's Avatar
any ideas? thanks
post #5 of 7 Old 03-08-2013, 08:40 AM - Thread Starter
jazzgtrl4's Avatar
bump
post #6 of 7 Old 03-08-2013, 08:45 AM
hakstone's Avatar
Sounds like a ground issue. Check speaker connections/polarity. Make sure reciever is properly grounded.
hakstone is offline
post #7 of 7 Old 03-18-2013, 12:03 PM - Thread Starter
jazzgtrl4's Avatar
Hi did that not a ground as it goes away after awhile..still trying to figure this out, any ideas?
