Yamaha RX-V373 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 02-12-2013, 02:33 PM - Thread Starter
keithyd's Avatar
Bought a new house and plan to buy a new system. I'm not someone that can notice a huge difference in audio distinction, but I want something decent and that will work well.
I'm looking for a receiver that is less than $250 to go along with the speakers that unfortunately go in the ceiling (Not center). Any recommendations on the Yamaha or others out there within the budget?
Thanks for your help.
keithyd is offline
post #2 of 10 Old 02-13-2013, 07:29 AM
miacane86's Avatar
For what it's worth, I just ordered mine yesterday. Same sort of requirement - budget system, reasonable performance. It's going to be 3.1 for now - pairing with Klipsch Quintet IVs (last year's model) I got on clearance for $130 at Best Buy, and a Polk PSW10 I got for 99 on Amazon. Obviously some upgrading in my future, though no plans for at least a year or more, but better than any HTIB.
miacane86 is offline
post #3 of 10 Old 02-13-2013, 07:47 AM
vegeta13613's Avatar
I was absolutely loving my v373, until I started getting a problem with dropping of the video signal. I have posted about it here, but have not been able to fix the problem. It might be a handshake issue, from what a few local techs have told me. However, Yamaha has never posted a firmware update for the v373, so it might be impossible to fix. Just the two cents of a newbie.
vegeta13613 is offline
post #4 of 10 Old 02-13-2013, 10:43 AM
miacane86's Avatar
Good to know, and an issue I'll keep an eye out for. I've been having some handshake issues with my new LG 47CM565 (flashing black for a second or so), but I've chalked that up to the HDMI cables I ordered a couple years ago, which are apparently 1.2 standard/have reviews saying this sort of thing happens. Ordered some BlueRiggers (good reviews on Amazon) to pair with this new setup. Worst case scenario, I have 30 days. 373 in general gets rave reviews though.
post #5 of 10 Old 02-13-2013, 10:43 AM
miacane86's Avatar
post #6 of 10 Old 06-11-2016, 04:42 AM
Liked: 0
please i need Firmware and Software update HTR-3065 or rx-v373 .No update at the site of Yamaha needed from somewhere else, please.
lyth-yamaha is offline
post #7 of 10 Old 06-11-2016, 10:00 AM
afrogt's Avatar
Quoted: 1334 Post(s)
Liked: 923
How do you know there is a software update available for the rx-v373 if its not on the Yamaha site?
Also, this is a reason to buy a receiver with networking so that you can easily do firmware updates. The RX-V3xx series doesn't offer networking. Go 4xx and higher.
Afro GT
afrogt is online now
post #8 of 10 Old 06-12-2016, 12:50 AM
Liked: 0
Thank you for your interest for my question. I agree with you that he does not support network. But what is the solution I have a problem and tells me there is an internal error
How do I finish this problem (internal error) ؟؟
post #9 of 10 Old 06-12-2016, 10:11 PM
afrogt's Avatar
Liked: 923
Maybe try doing a processor reset?
Afro GT
post #10 of 10 Old 06-13-2016, 12:06 PM
Liked: 0
Yes I did it. But it will not change on the screen continued internal error
Yamaha Rx V373 5 1 Channel Av Receiver
