Denon 1613 or 1713 (Help) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 02-12-2013, 09:27 PM - Thread Starter
alexander33's Avatar
Hello, I am putting together a simple 2.1 HT system in my bedroom 13x14 ft.
2 front speakers, a subwoofer, and a receiver. (Maybe a Blu-ray player)
Will the Denon AV 1613 (recommended) Refurbished Accessories4less $229.99
Power Output; Watts Per Channel 75
be sufficient or do I need the AVR 1713 Refurbished Accessories4l3ss 329.99
Power Output Watts per channel 80
No 3-D needed
Main use will be for watching TV low to medium listing level. (not laud)
I will appreciate recommendations and advice
Thanks, alexander
alexander33 is offline
post #2 of 8 Old 02-12-2013, 09:33 PM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3076
The difference in power between the two is insignificant. I would go with the 1713 since it has Audyssey MultEQ XT which is superior to the MultEQ the 1613 has. Both have Airplay and a USB port if these features are important to you.
Living Room: B&W 804D, B&W CMC S2, B&W ASW610, Yamaha RX-A2030, Rotel RC-1570, Rotel RB-1582 mkii, Oppo BDP-93, ATV.
postrokfan is offline
post #3 of 8 Old 02-13-2013, 08:09 AM - Thread Starter
Thank you for the recommendation. I will place an order on Accessories4less for the Denon 1713 .$329.99
Is the extended warrantee something I should purchase Please your recommendation:
NEW LEAF Service Pro 2 Year Total Protection Plan
2 Year Total Protection Plan adds 1 year to manufacturer’s warranty $24.99
Is accessories4less the best place to purchase from? alexander33
post #4 of 8 Old 02-13-2013, 08:44 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
In your opinion is the difference in Audyssey support the major difference between these two products?
arnyk is offline
post #5 of 8 Old 02-13-2013, 10:16 AM
butie120's Avatar
Quoted: 339 Post(s)
Liked: 67
I too would appreciate to hear others thoughts on these questions.
butie120 is online now
post #6 of 8 Old 02-13-2013, 05:14 PM
jdsmoothie's Avatar
Quoted: 12079 Post(s)
Liked: 5500
Yes, AC4L is the best place to purchase a "refurb" other than purchasing it from Denon directly when they have sales. Also check to see if your credit card provider will add a 2nd year of warranty to the 1 year already provide by Denon as Amex will and some MC/Visa providers will as well. If not, the New Leaf plan would be a worthwhile purchase.
jdsmoothie is offline
post #7 of 8 Old 02-13-2013, 09:22 PM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3076
IMO, yes. The 1713 also offers more connectivity and 2nd zone capability.
post #8 of 8 Old 02-14-2013, 05:07 AM
Quoted: 73 Post(s)
Liked: 112
I'd go with the 1713. MultEQ XT is worth it.
rnatalli is offline
Denon Avr 1613 Receiver , Denon Avr 1713 Receiver
