Dissapointed with RX-573 / AV Controller...Will 673 fix this? - AVS Forum | Home Theater Discussions And Reviews
Old 02-14-2013, 05:46 PM - Thread Starter
robpiat's Avatar
So after doing a fair amount of research and reading the manuals etc. I bought a Rx-573. My hope was to have my theater on SPK A and my outdoor speakers on B. This is all setup and working great with the exception of one thing. The Yamaha AV Controller app can't control the speaker zones. Best I can tell the only way to this is through the front panel and/or IR remote.
When I initially looked at the AV controller software, it shows zone control, but it is not shown on my app. I am thinking zone control is only for the 673 and higher? I'd really like to just use an app to turn the outdoor speakers on. I don't have any need to being using both at once with different programming.
My options seem to be
- Try a 673 and move this receiver elsewhere
- Use a separate dedicated airplay compatible receiver for the outdoor speakers
- find an app controlled IR blaster to change the A/B setting
Am I missing something?
robpiat is offline
Old 02-14-2013, 08:59 PM
All-Or-Nothing's Avatar
All-Or-Nothing is offline
Old 02-14-2013, 09:03 PM - Thread Starter
robpiat's Avatar
Sorry if I was unclear. All is well when I am in the room. I would like to be able to use the av controller or another app to turn on the stereo, switch to speaker b, etc from outside the house.
robpiat is offline
Old 02-16-2013, 05:59 PM - Thread Starter
robpiat's Avatar
Any other ideas?
robpiat is offline
