External IR receiver for AVR 235? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-16-2013, 02:35 PM - Thread Starter
andresastor's Avatar
Hi, i don´t know if this answer is solved yet , but i couldn´t find it.
I have a HK235 AVR and i want to connect an external IR receiver because i have a table in front of it that difficults the communication with my remote.
I want to locate a receiver on the tv and i know that HK have the HE-1000 IR receiver for this situations, but its too expensive for me, because i don´t want to connect a piramidal system with other components.
Anyone knows other compatible IR sensor for what i need?
Thank you.
andresastor is offline
post #2 of 5 Old 02-17-2013, 01:28 PM - Thread Starter
Nobody can help me?, no compatible IR receiver?
post #3 of 5 Old 02-17-2013, 05:30 PM
GregLee's Avatar
Quoted: 868 Post(s)
Liked: 296
I don't know anything about your receiver. For my Onkyo 3008 AVR, I've used this IR repeater for two years, and it has worked fine.
Greg Lee
GregLee is offline
post #4 of 5 Old 02-18-2013, 02:26 AM - Thread Starter
Thank you. I will test it and before I will comment here my impressions.
post #5 of 5 Old 02-28-2013, 07:08 AM - Thread Starter
It works fine, very useful IR repeater. You can connect a direct cable to the IR port on your HK and it works pretty good.
Thank you for the information
