Denon AVR 1609 question - AVS Forum | Home Theater Discussions And Reviews
Old 02-16-2013, 04:25 PM - Thread Starter
idea3's Avatar
Hi
I am trying to setup my speakers using Audessey setup on my Denon 1609. I start the procedure, while it checks the first speaker (left front) it disconnects the receiver. It just shuts it down. Why? I am trying to set the speakers up after moving and I added the subwoofer, which I want the receiver to detect (it's not working).
Can anybody help me?
Thanx
idea3 is offline
Old 02-16-2013, 09:48 PM
jdsmoothie's Avatar
Quoted: 12180 Post(s)
Liked: 5548
Make sure the speaker wiring is correct for each post (ie. no stray stands touching another post) and if yes, the try resetting the microprocessor (p. 44 OM).
jdsmoothie is offline
Old 02-17-2013, 06:59 AM - Thread Starter
idea3's Avatar
the cables were touching. Thanx
idea3 is offline
Old 02-17-2013, 07:20 AM
jdsmoothie's Avatar
Liked: 5548
Be sure to spend some time reviewing the Audyssey 101/FAQ Guide linked in my sig to get the best use out of Audyssey (to include using either a tripod or mic boom stand to support the mic).
