Amp for focals? What to get? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 02-18-2013, 04:13 PM - Thread Starter
shortyg83's Avatar
Quoted: 940 Post(s)
Liked: 884
Ok I am ordering Focal 814v tomorrow. I am looking for an amplifier for them. Strictly a stereo setup for music. I am ok with either separates or integrated. And would prefer not to get a receiver style.
Closer to 200wpc the better. As for budget, 1k. But from what I have read here the SQ doesn't change that much on solid state amps very much, so if below 500 works that would be great.
shortyg83 is online now
post #2 of 16 Old 02-18-2013, 06:33 PM - Thread Starter
shortyg83's Avatar
Quoted: 940 Post(s)
Liked: 884
Also integrated may be better if anyone thinks that will work.
post #3 of 16 Old 02-19-2013, 05:21 AM - Thread Starter
shortyg83's Avatar
Quoted: 940 Post(s)
Liked: 884
How is something like the nad 2700 or the carver m400
post #4 of 16 Old 02-19-2013, 02:10 PM - Thread Starter
shortyg83's Avatar
Quoted: 940 Post(s)
Liked: 884
Guys I really hate to bump this but I need to find an amp quick. It does not have to be integrated. And I would prefer close to 200wpc, My funds took a hit tho I only have 500 bucks.
I am currently stuck on a Nad 2700 doing 150 wpc. Should I buy that or is there something else?
post #5 of 16 Old 02-19-2013, 03:31 PM
kouack's Avatar
the difference between 150 watts to 200 watts is minimal just a waste of money imo.
Warning to prevent risk of injuries, you should always be smarter than the equipment you are about to use.
kouack is offline
post #6 of 16 Old 02-19-2013, 03:52 PM
Paraneer's Avatar
Quoted: 24 Post(s)
Liked: 75
Yeah, I agree with kouack. Also, the Focals are very efficient at 91.5 db and 8 Ohms. 150 wpc would be more than plenty to drive them.
Marantz PM15S2 LE, Oppo BDP-103, Simaudio Moon 100D DAC
VPI Traveler V2 with an Ortofon Rondo Blue and Simaudio Moon 110LP, Technics SL-1400 with an Audio Technica AT-14sa and Pro-ject Phono Box S
Dynaudio Focus 260's, Rel T-1 and a Panasonic TC-P54S1.
Paraneer is offline
post #7 of 16 Old 02-19-2013, 07:23 PM
justindo's Avatar
I've got the 814s and they're nice speakers and luckily pretty efficient, because you're not going to find a particularly powerful amp for your budget.
In this price range I'd take a look at NAD, Rotel, Cambridge, Onkyo, and Marantz. The Absolute Sound raved about the NuForce, but it doesn't have any analog inputs. What Hi-Fi likes the Cambridge. Personally, if it were me I'd probably opt for the 75 wpc Music Hall a15.2 http://www.insound.com/Music-Hall-A152-Integrated-Amp-Amp-Music-Hall/P/INS103751/
justindo is offline
post #8 of 16 Old 02-19-2013, 07:27 PM - Thread Starter
shortyg83's Avatar
Quoted: 940 Post(s)
Liked: 884
The music hall is a lot lower power wise than I want. My hk reciever puts out that power. I am looking for something with more power.
post #9 of 16 Old 02-19-2013, 07:29 PM
justindo's Avatar
If your budget is only $500, I'd probably just keep the H/K and power the Focals with it.
justindo is offline
post #10 of 16 Old 02-19-2013, 07:47 PM - Thread Starter
shortyg83's Avatar
Quoted: 940 Post(s)
Liked: 884
The problem is the hk is being used in a different room for a home theater setup. These speakers are just for music in a different room and I would like something higher power.
post #11 of 16 Old 02-21-2013, 10:38 PM
justindo's Avatar
Given the efficiency of the Focals, I wouldn't be too concerned with a powerful amp. I'd focus more on quality than quantity, especially since the latter is difficult to find given the budget.
justindo is offline
post #12 of 16 Old 02-22-2013, 07:22 AM
Paraneer's Avatar
Quoted: 24 Post(s)
Liked: 75
Again, I agree with everyone above. You don't need 200 watts with Focals. Justindo said it best - focus on quality! Besides there are very few integrated amps out there at 200 wpc. The ones that are out there, are way beyond your stated budget. Even used. And I assume we are talking used.
I am curious why you want 200 wpc? If the reason for so much power is to listen at extemely loud, ear bleeding levels, 200 wpc with the Focals is not going to get you there. You bought the wrong speakers.
Paraneer is offline
post #13 of 16 Old 02-22-2013, 08:51 AM - Thread Starter
shortyg83's Avatar
Quoted: 940 Post(s)
Liked: 884
The reason for the 200wpc was the focal specs list that as their top power rating.
But I followed some advice on here and ended up gettin a Rotel RB-1070. So I will have 130wpc. I am hoping it all sounds good.
post #14 of 16 Old 02-22-2013, 09:17 AM
Paraneer's Avatar
Quoted: 24 Post(s)
Liked: 75
Power handling ratings on speakers are a meaningless spec. Its sensitivity and impedence specs that matter. You did well getting the Rotel - it will be more than enough for the Focals. Sounds like you will have a very nice system. Enjoy it.
Paraneer is offline
post #15 of 16 Old 02-22-2013, 10:58 AM
justindo's Avatar
The Rotel is a good amp and has plenty of power for the Focals. What are you using for a preamp?
justindo is offline
post #16 of 16 Old 02-22-2013, 12:12 PM - Thread Starter
shortyg83's Avatar
Quoted: 940 Post(s)
Liked: 884
No idea what to use on a pre amp yet I will be currently using my HK avr 240 until I figure something out. Most music will come from laptops so I need a usb DAC as well.
