looking for a Receiver wih 4ohm capability. - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 47 Old 02-20-2013, 06:48 AM
wronganswer's Avatar
Pioneer sc1522 is 4ohm certified... Also the sc1222
wronganswer is offline
post #32 of 47 Old 02-20-2013, 07:03 AM - Thread Starter
budget.
regizzle is offline
post #33 of 47 Old 02-20-2013, 09:36 AM - Thread Starter
regizzle is offline
post #34 of 47 Old 02-20-2013, 09:37 AM - Thread Starter
regizzle is offline
post #35 of 47 Old 02-20-2013, 09:48 AM
afrogt's Avatar
Quoted: 1055 Post(s)
Liked: 757
No audio over HDMI on the 1609.
The 588 doesn't have HDMI at all.
They basically have the same power as the 1612 or 1613 so you might as well get one of them. Still dont think those entry level Denon's are good at 4 ohm loads.
i want hdmi i didnt notice... ugh... that denon is absolutely perfect aside from the hdmi!!! >_< why is this so hard?
Honestly, because you're being cheap.
Afro GT
afrogt is online now
post #36 of 47 Old 02-20-2013, 10:10 AM - Thread Starter
im not trying to be cheap trust me if i had the funds i'd be all over something with a great spec sheet however im constricted. so you think i should just get that 80 dollar avr and run components? my only concern is the way my tv is mounted its a pain to get to the component cables, thus why hdmi makes my life that much more simple but considering this a "bandaid" of sorts for a years time. what do you suggest of the AVRS metioned, which should i buy?
1. http://miami.craigslist.org/mdc/ele/3558272233.html
2. http://miami.craigslist.org/mdc/ele/3606141899.html
3. http://www.accessories4less.com/make-a-store/item/DENAVR1613/DENON-AVR-1613-5.1ch-Networking-Receiver-w/AirPlay-3D-ready/1.html
4. Pioneer VSX-816-K
5. http://miami.craigslist.org/mdc/ele/3608505786.html
will be buying one of these 5.
1,2,and 5 have my vote. plus fast to get them.
regizzle is offline
post #37 of 47 Old 02-20-2013, 11:10 AM - Thread Starter
regizzle is offline
post #38 of 47 Old 02-20-2013, 11:37 AM - Thread Starter
come on girls my packages arrive today.
regizzle is offline
post #39 of 47 Old 02-20-2013, 12:21 PM - Thread Starter
bumps
regizzle is offline
post #40 of 47 Old 02-20-2013, 02:30 PM - Thread Starter
come on ^_^
regizzle is offline
post #41 of 47 Old 02-20-2013, 04:20 PM - Thread Starter
regizzle is offline
post #42 of 47 Old 02-20-2013, 06:30 PM
afrogt's Avatar
Liked: 757
1 and 2 do not have preouts to add an amp if you need one. $225 is way too much to pay for the Denon 588.
5 will have the most power
What video sources do you have? Cable/Sat box? DVD? Blu Ray?
Afro GT
post #43 of 47 Old 02-20-2013, 07:52 PM - Thread Starter
cable box, pc
regizzle is offline
post #44 of 47 Old 02-21-2013, 12:06 PM
afrogt's Avatar
Liked: 757
cable box, pc
Are they both HDMI? What type of audio connections does the PC have?
If this is just a temporary solution you may be fine with the Denon 3802. I know the cable box has optical and digital coax audio outputs if its an HD box. Don't know about your PC, you'll have to provide that info.
since you only have 2 devices you could probably connect those directly to your TV for video.
Afro GT
post #45 of 47 Old 02-21-2013, 12:50 PM - Thread Starter
yes sir , both hdmi
regizzle is offline
post #46 of 47 Old 02-22-2013, 07:33 AM
GregLee's Avatar
Quoted: 825 Post(s)
Liked: 262
This is not my opinion, but some people think that driving 4 ohm speakers is no big deal, because ordinary receivers have no problem doing it, even though they may not be rated for 4 ohm operation. Here is a discussion thread on the Axiom forum with that view represented: http://www.axiomaudio.com/boards/ubbthreads.php?ubb=showflat&Number=323#Post323.
Greg Lee
GregLee is online now
post #47 of 47 Old 02-27-2013, 08:57 AM - Thread Starter
sooo buying this tomorrow:
http://www.amazon.com/Onkyo-TX-SR705-Channel-Theater-Receiver/dp/B000OBMX0K
Say your issues with it before i go out and buy it.
regizzle is offline
