What would be best AV Receiver for under $1000 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 02-18-2013, 09:37 PM - Thread Starter
bolshoyg's Avatar
Hey I need advice on a receiver? I had Yamaha YHT-900 6.1 in box home theater system with HTR-5560 receiver. It served me for more then ten years, i enjoyed it A LOT. It was really outdated and i sold the receiver, but still have 6 wood shelf speakers model #NS-AC580 6 ohms and 45 watts with subwoofer. Ok here is the question: im starting from the beginning, What would be the best receiver that i could use with my speakers. I would like a DLNA connection and Air play, bluetooth is optional. Any advice?
bolshoyg is offline
post #2 of 9 Old 02-18-2013, 10:27 PM
GaryWA's Avatar
Quoted: 16 Post(s)
Before you buy a 1000$ receiver, you should proportion your speakers to be at least 2x the cost of the receiver. So you would need $2000 worth of speakers for a $1000 receiver. For those speakers, something like a Denon 1713 would suffice.
bolshoyg likes this.
GaryWA is offline
post #3 of 9 Old 02-19-2013, 06:16 AM
GregLee's Avatar
Quoted: 868 Post(s)
Liked: 296
Pioneer SC-1522-K. Price at Amazon is just under your limit. 9.2 channels with the features you mention. Bluetooth requires an optional $99 accessory.
Greg Lee
GregLee is offline
post #4 of 9 Old 02-19-2013, 07:22 AM
afrogt's Avatar
Quoted: 1414 Post(s)
Liked: 968
With those Yamaha speakers all you need is an entry level receiver. You definitely don't need to spend up to $1000.
What devices will you be connecting? Are they all HDMI?
Something like the Denon 1713. Pioneer VSX-1022, and Yamaha 573 all have Airplay and DLNA and may be more than enough for your needs.
Afro GT
afrogt is offline
post #5 of 9 Old 02-19-2013, 09:14 PM - Thread Starter
bolshoyg's Avatar
Thanks for some good advices, well as i mention im starting from scratch and thinking in the future to purchase a Panasonic Plasma TV ST-50 or VT-50 it is all depends on the purchase of receiver first. Yes most of all its going to be HDMI connections only. For the speakers i was thinking they will work good for so-round sound but for music maybe in near future i could by some decent pair of speakers...
any thoughts on Marantz NR1603 or Sony STRDN1030? Both CNet and Hometheather.com are giving good review for Sony.
bolshoyg is offline
post #6 of 9 Old 02-19-2013, 09:20 PM
javygonx's Avatar
Quoted: 100 Post(s)
Liked: 27
My vote goes for Piomeer sc-1522
javygonx is offline
post #7 of 9 Old 02-19-2013, 10:16 PM
Ryder125's Avatar
Anthem MRX-300 is $950USD so that'll be my vote, I haven't heard the Sherwood R-972 Newcastle but at $599 I believe they sell for with the Trinnov Optimizer should be on this list as well but it's pretty ugly looking.
Ryder125 is offline
post #8 of 9 Old 02-20-2013, 08:52 PM - Thread Starter
bolshoyg's Avatar
Ok guys it seems like im little stuck and need your advice on three AV Receivers;
1. Onkyo TX-NR616 7.2-Channel
2. Denon AVR-1913 7.1 Channel or Denon AVR-2113CI
3. Marantz NR1603
I like Onkyo because of the options it comes with but as a brand not sure, not familiar with it and of the cons is that it does not have air play... The options Onkyo comes with matching with Denon avr-2113CI but much cheaper then all. The only pro for Marantz NR1603 that it slim and would fit the best in my place and 3 year warranty sounds good.
Any thoughts what would be better?
bolshoyg is offline
post #9 of 9 Old 02-21-2013, 08:12 AM
hery19's Avatar
Quoted: 26 Post(s)
3. Marantz NR1603
Would you consider a used receiver? If you would, I have a Denon AVR-3311ci that meets and exceeds all your requirements. Have Rotel separates so no longer need for the Denon.
TV:Mitsubishi WD 73833, Receiver:Anthem MRX 720, Bluray: OPPO BDP-93, Conditioner:Panamax M4300-PM, Speakers:B&W CM4 Fronts, CMC center, CM2 Surrounds, Sub: SVS PB1-ISD & Remote:Harmony One
hery19 is offline
Yamaha Htr 5560 Dolby Digital Audio Video Receiver , Denon Avr 1713 Receiver , Pioneer Sc 1522k 9 2 Channel Av Receiver , Pioneer Vsx 1022 K 560w 7 Channel A V Receiver , Yamaha Rx V573 Receiver , Panasonic Viera Tc P50st50 Plasma Tv , Panasonic Viera Tc P55vt50 , Marantz Nr1603 Slim Line Av Receiver , Sony Strdn1030 Receiver
