Shutting down my receiver makes a startling noise - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-19-2013, 12:46 PM - Thread Starter
cloverblack's Avatar
Hi, complete n00b here (and first post) , sorry if this is in the wrong forum.
Just hooked up a Yamaha RX-V373 receiver to some in-ceiling polks & center. Everything seems to be going swimmingly when I turn on the receiver , view movies / cable / usb / music.
When I turn the receiver off, it emits a loud and quick shriek/screech (turning it off via the remote). Does anyone have any suggestions what the cause could be?
Thanks for your help, in advance, and again sorry if this is not the correct forum.
cloverblack is offline
post #2 of 3 Old 02-19-2013, 01:10 PM
Espo77's Avatar
Quoted: 182 Post(s)
Liked: 85
Do you turn the volume down before powering off? This is a pain, but unhook all components and try just the FM tuner built into the receiver, to see what happens.
Espo77's living room equipment: RECEIVER: Yamaha RX-A3030- SPEAKERS: Boston Acoustics M350, M25 center, surrounds, and front heights-
BLU-RAY: Oppo BDP103D- SUBWOOFER: HSU VTF-15H MK2- dedicated circuits for A/V- TV: Vizio P55C-1
Auralex Acoustics LENRD - Auralex Acoustics Roominator
Espo77 is offline
post #3 of 3 Old 02-19-2013, 03:07 PM - Thread Starter
Thanks, will try that tonight.
I haven't tried turning the volume down, just the viewing volume I had it left at... It's been operational for about 1 day so I haven't tweaked it too much, and this has been my only quirk.
