Receiver impedance level - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 02-21-2013, 07:44 AM - Thread Starter
madhuski's Avatar
Quoted: 553 Post(s)
Liked: 289
Hello - if I have a receiver that allows you to select speaker impedance, what exactly does it do?
Ie I have songtowers in my setup and just wondering if its advantageous to just leave the receiver impedance setting at 8?
Selling in the Classifieds
Wyred4Sound MC7150 seven channel amp - $899
madhuski is offline
post #2 of 8 Old 02-21-2013, 08:15 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Typically the impedance switch selects different taps on the secondary of the power transformer. This results in changes to the DC voltage available to the output stage, which reduces its heat dissipation at the expense of maximum power output.
The purpose of the impedance switch relates to bench testing with pure tones. Any real world source of music has 4-10 times or more times less heat-producing capability than a pure tone with the same peak level.
arnyk is offline
post #3 of 8 Old 02-21-2013, 11:21 AM
M Code's Avatar
Quoted: 717 Post(s)
Liked: 419
The primary purpose of the impedance switch is to protect the AVR's amplifier output stage from destruction...
Todays AVRs are typically built under very tight component material cost budgets, so the brand strives to save $..
If one is running low impedence/sensitivity full-range loudspeakers and being driven to higher SPL levels, it is easy for the AVR's power supply and amplifier output stage to be stressed. And amplifier stage failure is one of the major reasons AVRs are sent in for warranty repair...rolleyes.gif
Its basic function is too limit the current available, by reducing the power supply to a calculated max voltage output. Also when set to a lower impedence position such as 4 or 6 Ohms, the dynamic range capability of the amplifier is reduced as the amplifier stage has max output (voltage & current) without this limitation. So for the highest sonic performance it is best to leave it in the 8 Ohms position.
M Code is online now
post #4 of 8 Old 02-22-2013, 03:05 PM
Pat315's Avatar
Even if the speakers are 6ohm?
Pat315 is offline
post #5 of 8 Old 02-22-2013, 05:40 PM
JHAz's Avatar
Quoted: 305 Post(s)
Liked: 271
yes. it's not a tube amp that requires (or at least performs optimally if) the output transformer properly matches the speakers. what people are saying is that with a solid state amplification device there is no need to match output impedance to the speaker impedance. and that's not what those switches do. They just keep the amp from making as much power as it otherwise would, mostly to keep regulatory authorities happy so it won't get too hot under any conditions. If you listen to music and watch movies (rather than playing pure sine waves at max output) you are quite unlikely to encounter a heat problem. Unless you have very inefficient speakers that you sit very far from and listen very loud.
you can do what the switch does just by turning down the volume control, in other words. except with the switch on the lower impedance setting you'll get more distortion at higher sound levels, which you don't really want to recreate anyway.
JHAz is offline
post #6 of 8 Old 02-22-2013, 06:12 PM
M Code's Avatar
Quoted: 717 Post(s)
Liked: 419
Regardless of the brand/model loudspeaker connected, leave the switch in the 8 Ohms position..
post #7 of 8 Old 02-23-2013, 05:31 AM
Pat315's Avatar
Ok thanks
Pat315 is offline
post #8 of 8 Old 02-23-2013, 07:20 AM - Thread Starter
madhuski's Avatar
Quoted: 553 Post(s)
Liked: 289
Thanks guys!
madhuski is offline
