Cerwin Vega CXA8 vs CV1800 vs Emotiva XPA5 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 02-22-2013, 06:17 AM - Thread Starter
tcsekhar's Avatar
I'm looking towards building my home theater and comparing different class AB amplifiers and narrowed down to CV and Emotiva. I don't have any doubts about Emotiva but unsure about CVs though they had been around for quite a while with no place to compare them.
My questions are is there a lot of difference between the quality between CXA8 and CV1800 (by specs I couldn't find any major difference). If fan noise is the only drawback, I don't mind as I have a separate noise proof room for the amps. And, are they even close to compare with Emotiva?
tcsekhar is offline
post #2 of 2 Old 03-01-2013, 09:51 AM
mr edward's Avatar
Cerwin-Vega! has a long reputation for building quality products that provide clear sound at the loudest levels, so be confident that both models are made to the highest standard possible.
Home theater enthusiasts will always be building to the latest and greatest. With a basic two channel, two rack unit height Cerwin-Vega! amplifier, at a later time you can always upgrade to higher power version (more power never hurt!). Or buy another to add more channels. You can also argue that it’s better to share one power supply with 2 channels than with 5 channels on the Emotiva XPA-5. And racking a box that’s almost half the weight will always be easier.
FYI, Check out Emotiva’s Audio Precision report on their website. Emotiva claims 300Watts into 4-ohms (@ THD 0.1%) yet the plot on Page 6 shows THD breaking the 0.1% limit way before it can reach 300Watts. Ouch, it must be the power supply! Might as well stick with the amps in an AVR or expect home theater in a box performance (sarcasm).
mr edward is offline
Emotiva Xpa 5 5 Channel Power Amplifier
