Having an issue with my Onkyo TX-NR809 and Video. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 02-23-2013, 06:26 PM - Thread Starter
mudfrog's Avatar
Quoted: 20 Post(s)
When watching movies on my HTPC and using HDMI through the receiver, once I maximize to full screen the entire screen will shift about an inch to the left cutting off the left side and leaving a black bar on the right side. It did not do this with the Onkyo 509 that I replaced so it is an issue with the 809. Is there a setting I should look for or would this be a hardware issue?
Equipment - 60" Vizio M60-C3 - Denon AVR-2300W - Pioneer BDP-150 - HTPC, Xbox One - Sennheiser RS170 Headphones - APC C25B Power Filter
Speakers - SVS Prime Center, Bookshelves, Satellites, Dual BIC F12 12" Subs
HTPC - Intel Core i3-3220, 8GB DDR3 1600, 750ti 2GB, 7TB of HDD's, LG Bluray
mudfrog is offline
post #2 of 2 Old 02-25-2013, 08:26 AM - Thread Starter
mudfrog's Avatar
Quoted: 20 Post(s)
If I switch from the PC input to another input and back again it will display correctly until I enter full screen again.
mudfrog is offline
Onkyo Tx Nr809
