RCA cable question... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 02-26-2013, 07:57 AM - Thread Starter
Tcuguy27's Avatar
Just purchased a new anthem processor and amp. What RCA cable should i use to connect the two. These things seem to widely vary in price, style, etc. I've seen people say go to Radio Sheack and get the cheapest ones you can find, to others saying you need to spend money on top of the line cords as you do not want this to be the weakest link in your system.
Any recomendations would be helpful??
Tcuguy27 is offline
post #2 of 15 Old 02-26-2013, 08:02 AM - Thread Starter
Tcuguy27's Avatar
Tcuguy27 is offline
post #3 of 15 Old 02-26-2013, 08:16 AM
JBWIII's Avatar
Liked: 43
Like you said, opinions vary on this issue. The one thing that people do agree on is that since this is an analog signal (as opposed to a digital signal like HDMI or optical), the cable can degrade that quality. That being said, I'd sleep soundly at night with those Monoprice cables in my system. I have a few and they're sturdy, high-quality cables that are just as nice as (and a fraction of the price of) some Monster RCA cables that I have.
The Monoprice cables and connectors are pretty stiff, so make sure that you have clearance behind your components. You can't mash them into right angles like you can with the flimsy RadioShack cables.
JBWIII is offline
post #4 of 15 Old 02-26-2013, 08:29 AM - Thread Starter
Tcuguy27's Avatar
Nice, thanks for the advice.
What about these audioquest cables? A friend told me about these....
http://www.audioquest.com/seventy-five-ohm/vdm-1
http://www.audioquest.com/snakes-rivers/diamond-back
Tcuguy27 is offline
post #5 of 15 Old 02-26-2013, 08:37 AM
JBWIII's Avatar
Liked: 43
That 75-ohm cable isn't meant for line-level analog audio (which is what you're sending). If you want to spend $150 on cables, go for that Diamondback. However, if you do, never ever buy the Monoprice cables and A/B test them. Because I'm betting that if you do, you won't be able to hear a difference and then you'll kick yourself for spending $140 too much. wink.gif
JBWIII is offline
post #6 of 15 Old 02-26-2013, 08:41 AM - Thread Starter
Tcuguy27's Avatar
Big diffrence between the Audioquest and the Monoprice cable?? I'm running an anthem avm 40 into an Anthem MCA 20, lenght of cord will be anywhere from 3 to 5 feet.
Tcuguy27 is offline
post #7 of 15 Old 02-26-2013, 08:53 AM
JBWIII's Avatar
Liked: 43
I can't say since I've never owned Audioquest cables. Maybe someone with experience with both will weigh in...
JBWIII is offline
post #8 of 15 Old 02-26-2013, 10:44 AM
DonoMan's Avatar
Cheap is fine. The difference between cheap cables and expensive cables is NOT minor - it is completely non-existent. wink.gif
It matters a little bit with video. Or in noisy environments it can help for audio to use a good shielded coax cable, but those can still be plenty cheap and Monoprice has them available too.
Do keep your signal cables as far away as possible from power cables, though, and cross them at as close to a 90* angle (in whatever 2d plane you want) if necessary. That will help keep induced current out of your signal wires.
"Vintage" is good for wine, not for A/V equipment.
-Dan D.
DonoMan is offline
post #9 of 15 Old 02-26-2013, 11:33 AM - Thread Starter
Tcuguy27's Avatar
Okay, thanks for all of the advice above. Last question, are these two cables basically the same thing, which one would be better for my situation??
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021814&p_id=2864&seq=1&format=2
Tcuguy27 is offline
post #10 of 15 Old 02-26-2013, 11:35 AM - Thread Starter
Tcuguy27 is offline
post #11 of 15 Old 02-26-2013, 11:37 AM
afrogt's Avatar
Quoted: 1062 Post(s)
Liked: 768
Get the stereo cables since you basically get two 6 foot cables for the price of one.
Afro GT
afrogt is offline
post #12 of 15 Old 02-26-2013, 11:43 AM - Thread Starter
Tcuguy27's Avatar
One is describes as a digital coaxil cable, the other an analogue rca cable. Same thing??
Tcuguy27 is offline
post #13 of 15 Old 02-26-2013, 11:55 AM
afrogt's Avatar
Liked: 768
I own several of both, they work the same.
Afro GT
afrogt is offline
post #14 of 15 Old 02-26-2013, 12:12 PM
DonoMan's Avatar
Cable impedance doesn't matter for analog audio. It somewhat matters for digital audio though in practice even the crappy cables usually work fine for digital audio, unless perhaps you have a long run. It does somewhat matter for analog video, particularly the higher bandwidth (resolution) links. And of course it's extremely important for digital video, but you won't even be able to connect the wrong cables to digital video connectors anyway (and the right cables are generally still cheap for that stuff anyway).
In other words, digital cables work for analog too, and while analog cables might not work for digital, they usually still do.
-Dan D.
DonoMan is offline
post #15 of 15 Old 02-26-2013, 12:25 PM
afrogt's Avatar
Liked: 768
Both cables are 75ohm anyway. One is just RG6, the other RG59. The RG59 is a little more flexible, RG6 is stiffer. These would both work for analog audio or video.
I've used both as digital coax, subwoofer, analog audio and analog video.
Afro GT
afrogt is offline
