Is it dangerous to adjust speaker levels to +10db - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 02-26-2013, 12:26 PM - Thread Starter
newtohometheate's Avatar
I have a Yamaha htr 4065 with pioneer speakers with fairly low sensitivity. In order to watch movies and comfortably hear dialogue I have to turn the volume up to -15 to -10 db. At this level movies sound very good, but at night it'll wake up the kids. Yamaha has adaptive dynamic range which is for nighttime viewing, but at high volume levels it dissapears. At lower volume levels it equalizes the range. My problems is that at lower volume levels I can't hear the dialogue even with adaptive drc on. So in order to make adrc more effective for night time viewing I was thinking of increasing all of my speakers levels +10, so adrc could possibly be more effective. The reciever also has a setting for max volume with is +16.5 db. I was thinking that in order to safe proof me from going to loud I would lower the maximum volume to +5 db. Does this sound safe?
newtohometheate is offline
post #2 of 6 Old 02-26-2013, 12:30 PM
DonoMan's Avatar
It doesn't matter what the number is if the volume is good to you and distortion is within acceptable limits (e.g. you aren't clipping, etc.). It varies depending on all of your other stuff.. receiver, speakers, speaker/room setup, your listening point, your source itself (not just the hardware but the recording too), etc. It's not even possible to calibrate it except for a very specific set of criteria - the calibration would NOT hold for anything you watched or listened to. I mention this because every time I talk about how the volume control is relative - and it is - people come in with their favorite response, "Calibrate it!" Even if you calibrated it, if you just watch a different movie, or watch it from the couch instead of the chair, your calibration is no longer true and it becomes useless.
This applies to the speaker channel level adjustments also. They work the same way just that they are for individual channels and the number you set isn't shown on the front panel (but it will likely just change the maximum main volume such that the overall maximum gain is the same).
"Vintage" is good for wine, not for A/V equipment.
-Dan D.
DonoMan is offline
post #3 of 6 Old 02-26-2013, 12:32 PM
afrogt's Avatar
Quoted: 903 Post(s)
Liked: 689
I don't think it makes a difference if you adjust all levels by +10. All that does is lower the max volume.
Try it and see if it works.
Sounds like you might need to look into headphones for your late night viewing.
If dialogue is where you are having the problem why not just adjust the center channel level up?
Afro GT
afrogt is offline
post #4 of 6 Old 02-26-2013, 12:39 PM
DonH50's Avatar
Quoted: 1659 Post(s)
Liked: 1205
Increasing all speaker levels 10 dB is the same as turning up the volume 10 dB, a power increase of 10x. Might as well keep calibration and turn up the volume, but I assume that won't help with the night mode system.
If the majority of your listening is at night you could try bumping up just the center trim by 3-6 dB to enhance the dialogue, and/or tweak the center EQ (if possible in your AVR) to boost the upper voice bands, say 1 - 3 kHz, to give vocals more "bite".
Get your kids a fan or white noise source in their rooms. Or get headphones. Or soundproof the room (that is NOT the same thing as adding acoustic treatment to the walls; isolation is usually much more involved). Or play a movie every night so they get used to it and will sleep through anything. Which they will do anyway once they hit the teen years. smile.gif
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is online now
post #5 of 6 Old 02-26-2013, 01:15 PM - Thread Starter
Thanks for the replies guys. I'm gonna boost each speaker level +10 db and see if that enhances the adaptive drc effect. Adjusting the center eq sound interesting; I don't really understand the different eq levels. Is it the eq "9" that needs to be boosted to enhance dialogue? I'll have to take a look at it when I get home from work.
post #6 of 6 Old 02-26-2013, 01:23 PM
DonoMan's Avatar
He was saying that in surround sound mode, dialogue typically comes from the center channel, so adjusting the center channel to be louder than the others (say leave your other speakers at +0dB in individual channel adjustment and maybe +5dB or even +10dB for center only) should allow the dialogue to be more audible without increasing most of the other stuff. The center channel is not JUST for dialogue, but that is its main purpose.
You can play with the equalizer too if you want. That's personal preference.
-Dan D.
DonoMan is offline
