Explain how to hook up an Arc receiver to a non Arc Hdtv using splitter? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 02-26-2013, 01:29 PM - Thread Starter
jbdog18's Avatar
Can someone please tell me how to hook up a non arc hdtv to an arc receiver using an hdmi switcher or splitter? Will doing so allow me to play the tv in surround sound 5.1/7.1/7.2?
jbdog18 is offline
post #2 of 7 Old 02-26-2013, 01:34 PM
JD in NJ's Avatar
Liked: 37
I'm not sure I understand.
Typically, unless something in the signal path does not work, you'd do source (blu-ray player) --HDMI--> Receiver --HDMI--> Television
ARC would only be needed to get sound from the TV (say, if your cable box is plugged into the TV, or you use an OTA antenna) to the receiver.
JD in NJ is offline
post #3 of 7 Old 02-26-2013, 01:45 PM - Thread Starter
jbdog18's Avatar
I would be using the sony kdl40ex640 and the sony strdn1030.
jbdog18 is offline
post #4 of 7 Old 02-26-2013, 01:47 PM - Thread Starter
jbdog18's Avatar
I want to be able to play the cable tv audio through the receiver.
jbdog18 is offline
post #5 of 7 Old 02-26-2013, 02:07 PM
GaryWA's Avatar
Quoted: 16 Post(s)
Not at all. The only reason for ARC is to get sound from the TV, but it doesn't mean that if one device is incompatible that everything else won't work.
GaryWA is offline
post #6 of 7 Old 02-26-2013, 05:39 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 191
If your receiver has HDMI inputs that process audio, there's no need for ARC. Like JD posted above, use HDMI connections and go cable box to AVR and AVR to TV.
BIslander is offline
post #7 of 7 Old 02-26-2013, 06:46 PM
JD in NJ's Avatar
Liked: 37
If using HDMI from your cable box to the receiver and then to the TV works, then you'll get cable TV audio through the receiver.
If, as is sometimes the case, HDMI fails to operate reliably, then you might need to fall back on plugging it directly into the TV and routing audio differently. This could be from the television either via ARC or optical or coaxial SPDIF. It could also possibly be from an SPDIF or other audio output on the cable box plugged separately into the AVR. It's a matter of finding what works best with your particular setup.
Be aware that the kind of lossless mutlichannel audio streams supported by Blu-Ray will not 'fit' into SPDIF, but Dolby Digital will, which is as much as you probably get via cable.
JD in NJ is offline
